StarTech.com 9 Pin Serial to 10 Pin IDC Header Low Profile Slot Plate Adapter
Quicklinx: 76TFWS00 Mfr#: PLATE9MHDLP
Allows Serial Slot plate connections to Small Form Factor motherboards in Low Profile enclosures. The PLATE9MHDLP low profile DB9 Serial Slot Plate Adapter Bracket adds a DB9 serial port to the rear panel of small form factor/low profile computer, connecting to the host computer motherboard using a mini style header connector (required by motherboards such as the Intel DG41).
StarTech.com Serial to 10 Pin IDC Header LP Slot Plate - serial adapter - DB-9 to 10 PIN IDC - 22.9 cm
Serial adapter
Low profile
Length
22.9 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial adapter
American Wire Gauge (AWG)
28
Low profile
Length
22.9 cm
Grey
Connector
10 PIN IDC - female
RoHS
