StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate
Quicklinx: 6BF5WS00 Mfr#: PLATE9MLP
Length: 23cm
More than 50 In Stock
£4.30 ex VAT
£5.16 inc VAT
This Low Profile DB9 Serial Slot Plate Bracket adds a DB9 serial port to the rear panel of small form factor/low profile computer, connecting to the host computer motherboard using an IDC10 connector. Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
  • Seamless compatibility
    Designed specifically for PC systems, this serial panel ensures a flawless connection between your motherboard and external devices.
  • Effortless installation
    The low-profile cable design and straightforward connectivity options make setup quick and easy, without the need for complex configurations.
  • Durable construction
    Built to last, this serial panel is compliant with RoHS standards, ensuring a reliable connection and extended product lifespan.
StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate - Serial panel - DB-9 (M) to 10 pin IDC (F) - 9.1 in - gray - PLATE9MLP - serial panel - DB-9 to 10 PIN IDC - 23 cm
Serial panel
Low profile
Length
23 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Grey
Serial panel
Low profile
Length
23 cm
Grey
Connector
10 PIN IDC - female
RoHS
6BF5 StarTech.com 9 Pin Serial Male to 10 Pin Motherboard Header LP Slot Plate In Stock £4.30
6BF5 StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate In Stock £5.20
6BF5 StarTech.com 2 Port 16in DB9 Serial Port Bracket to 10 Pin Header In Stock £5.96
Length: 23cm
