StarTech.com 8U WM Bracket for 12in Equipment
Quicklinx: CLVWWS00 Mfr#: WALLMOUNT8
Product Type: Cabinet
£103.61 ex VAT
£124.33 inc VAT
Mount equipment that is up to 12 inches deep, such as patch panels or network switches, to your wall. This wall-mount bracket provides 8U of space for mounting shallow rack-mount equipment that's 12 in. deep or less to the wall, such as patch panels or network switches.
The 8U rack optimizes your working space by efficiently mounting your shallow equipment on your wall instead of taking up desk space or other usable surface areas. It's the perfect solution for your space-limited SoHo (small office, home office) environment or server room because it doesn't take up any floor space.
The wall rack is constructed of solid steel to ensure a sturdy and safe mounting solution for your mission-critical equipment. Also, because the wall rack's mounting holes are positioned 16 in. apart, it exactly matches standard drywall construction framework to ensure simple and secure wall-stud anchoring.
The rack also features a rear access panel that can be used to easily run cabling into the rack.
Cage nuts and screws are included with the wall-mount bracket, to save you the hassle of sourcing separate mounting hardware.
If you're looking for a shallow mounting solution with fewer or more rack units, StarTech.com also offers a 6U wall-mount bracket, and a 12U wall-mount bracket.
Startech Wall Mount Patch Panel Rack - 4U Wall Mount Rack Shelf with Built in Shelf - 2 Post Open Frame Rack - Rack Shelf (WALLMOUNT8) - cabinet - 8U
Cabinet
Placing / Mounting
Wall mountable
Package Content
24 M5 cage nuts, 24 M5 screws with washers, M6 K-nut, 6 wood screws
Rack Size
12"
Height (Rack Units)
8U
Product Material
Steel
52.07 cm x 30.48 cm x 36.25 cm
7.1 kg
Cabinet
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Rack Size
12"
Height (Rack Units)
8U
52.07 cm
30.48 cm
36.25 cm
7.1 kg
8.1 kg
Inner Dimensions
44.97 cm x 34.29 cm
CLVW StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
CLVW StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
CLVW StarTech.com 6U 12in Deep Wall Mounting Bracket for Patch Panel In Stock £49.48
CLVW StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.44
CLVW StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
CLVW StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
CLVW StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
CLVW StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
CLVW StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
CLVW StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
CLVW StarTech.com 100 Pkg M5 Cage Nuts In Stock £30.81
CLVW StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
CLVW StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
CLVW StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
CLVW StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
CLVW StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
CLVW Startech.com 100 Pkg M6 Mounting Screws In Stock £26.84
CLVW StarTech.com 12U WM Bracket for 12 INCH Equipment In Stock £122.14
CLVW StarTech.com 8U WM Bracket for 12in Equipment In Stock £103.61
CLVW StarTech.com 4U Wall Mount Rack, 13.78in Deep, 19 inch Wall Mount Network In Stock £46.00
CLVW StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
CLVW StarTech.com 2U Wall-Mount Bracket In Stock £32.50
