Vertically wall-mount your server or networking equipment in this 8U network cabinet. This 8U vertical server cabinet offers a space-saving way to keep your network and server equipment secure. With its 30 in. depth, and a weight capacity of up to 200 lb. (90.7 kg), the server rack/cabinet is designed to fit your needs. It also features an additional 2U mounting bracket positioned toward the top of the enclosure that you can use to mount patch cables or other shallow rack-mount equipment.
Wall-mount your equipment, even if you don't have enough space for a full-sized rack or cabinet. This low-profile server cabinet is perfect for areas where space is at a premium, such as an office. The cabinet saves space by extending only minimally from the wall and housing the length of your equipment vertically. This reduces the horizontal footprint of your equipment while still providing plenty of room for your servers, patch panels, and switches.
To help keep your equipment secure, the vertical server cabinet/network rack features a sturdy metal design and a lock on both the door and access panel. It is also vented, providing passive cooling to help keep your equipment running at suitable temperatures.
The server rack comes fully assembled and includes all of the necessary hardware to install equipment, making installation fast and easy. The mounting holes are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common North American wall-frame stud spacing.
Secure Construction
Made from strong steel, this rack cabinet ensures protection and stability for mounted equipment. -
Efficient Space Utilization
The wall-mountable design allows for optimal use of vertical space, freeing up floor areas. -
Versatile Installation
With adjustable rails, this rack accommodates different types of equipment securely. -
Organized Cabling
The integrated cable management system helps keep wires neatly arranged, reducing the risk of tangles. -
Reliable Weight Support
Designed to support weights up to 90 kg, making it suitable for a range of networking gear.
- StarTech.com 8U 19" Vertical Wall Mount Server Rack Cabinet, Low Profile (15"), 30" Deep Locking Network Enclosure with 2U for Switch Patch Panel Router Mounting IT/Data Cabinet Assembled - 19 Inch Wallmount Rack (RK830WALVS) - rack enclosure cabinet - 8U
- Product Type
- Rack enclosure cabinet
- Placing / Mounting
- Wall mountable
- Package Content
- 2 door keys, 2 front panel keys, 32 screws (12-24), 32 plastic washers
- Black
- Height (Rack Units)
- 8U
- Product Material
- Steel
- 64.3 cm x 38.1 cm x 94 cm
- 36.5 kg
- Lockable front door, integrated cable management, adjustable rails, 2 post
- 5-year warranty
- Product Type
- Wall mountable
- Product Material
- Steel
- Package Content
- 8U
- 64.3 cm
- 38.1 cm
- 94 cm
- 36.5 kg
- Black
- Weight Limit
- 90 kg
- Limited warranty: - 5 years
StarTech.com 12-24 Server Rack Screws - 50 pack - Nickel-Plated | In Stock | £14.91 |
