StarTech.com 8U Vertical Server Cabinet
Quicklinx: D881WS00 Mfr#: RK830WALVS
Hurry, only 3 left in stock!
£296.17 ex VAT
£355.40 inc VAT
Vertically wall-mount your server or networking equipment in this 8U network cabinet. This 8U vertical server cabinet offers a space-saving way to keep your network and server equipment secure. With its 30 in. depth, and a weight capacity of up to 200 lb. (90.7 kg), the server rack/cabinet is designed to fit your needs. It also features an additional 2U mounting bracket positioned toward the top of the enclosure that you can use to mount patch cables or other shallow rack-mount equipment.
Wall-mount your equipment, even if you don't have enough space for a full-sized rack or cabinet. This low-profile server cabinet is perfect for areas where space is at a premium, such as an office. The cabinet saves space by extending only minimally from the wall and housing the length of your equipment vertically. This reduces the horizontal footprint of your equipment while still providing plenty of room for your servers, patch panels, and switches.
To help keep your equipment secure, the vertical server cabinet/network rack features a sturdy metal design and a lock on both the door and access panel. It is also vented, providing passive cooling to help keep your equipment running at suitable temperatures.
The server rack comes fully assembled and includes all of the necessary hardware to install equipment, making installation fast and easy. The mounting holes are spaced 16 in. apart, making it suitable for mounting on almost any wall, based on common North American wall-frame stud spacing.
  • Secure Construction
    Made from strong steel, this rack cabinet ensures protection and stability for mounted equipment.
  • Efficient Space Utilization
    The wall-mountable design allows for optimal use of vertical space, freeing up floor areas.
  • Versatile Installation
    With adjustable rails, this rack accommodates different types of equipment securely.
  • Organized Cabling
    The integrated cable management system helps keep wires neatly arranged, reducing the risk of tangles.
  • Reliable Weight Support
    Designed to support weights up to 90 kg, making it suitable for a range of networking gear.
StarTech.com 8U 19" Vertical Wall Mount Server Rack Cabinet, Low Profile (15"), 30" Deep Locking Network Enclosure with 2U for Switch Patch Panel Router Mounting IT/Data Cabinet Assembled - 19 Inch Wallmount Rack (RK830WALVS) - rack enclosure cabinet - 8U
Rack enclosure cabinet
Placing / Mounting
Wall mountable
Package Content
2 door keys, 2 front panel keys, 32 screws (12-24), 32 plastic washers
Height (Rack Units)
8U
Product Material
Steel
64.3 cm x 38.1 cm x 94 cm
36.5 kg
Lockable front door, integrated cable management, adjustable rails, 2 post
5-year warranty
Placing / Mounting
Wall mountable
Product Material
Steel
Package Content
Height (Rack Units)
8U
64.3 cm
38.1 cm
94 cm
36.5 kg
Weight Limit
90 kg
Limited warranty: - 5 years
D881 StarTech.com 12-24 Server Rack Screws - 50 pack - Nickel-Plated In Stock £15.40
