StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth
Quicklinx: 7P1FWS00 Mfr#: RK812WALLOA
Type: Wall Mount
Depth (mm): 51cm
Width (mm): 53.5cm
U Height: 8U
£133.49 ex VAT
£160.18 inc VAT
Mount your network and telecommunications equipment with the convenience of adjustable depth. The RK812WALLOA 8U Open Frame Wall Mount Equipment Rack with Adjustable Depth is a high-quality, sturdy relay rack solution that is easy to assemble and install into any environment. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
The open rack features an adjustable depth ranging from 12-20 inches, in order to accommodate larger data, network and telecommunications devices. The greater than average depth of the rack also allows for mounting of shelves and other accessories. The wall mounts are positioned 16in apart (center to center), making it suitable for mounting on virtually any wall surface, based on North American wall frame stud spacing standards.
This 8U rack can be mounted to the wall in a server room, office, or above a doorway, expanding your workspace and keeping your equipment easily accessible.
StarTech.com 8U 19" Wall Mount Network Rack, Adjustable Depth 12-20" 2 Post Open Frame Server Room Rack for AV/Data/ IT Communication/Computer Equipment/Switch with Cage Nuts & Screws - 8U Adjustable Rack (RK812WALLOA) - rack - 8U
Rack
Placing / Mounting
Wall mountable
Rack Size
20"
Height (Rack Units)
8U
Product Material
Steel
53.5 cm x 51 cm x 49.5 cm
10.8 kg
Adjustable depth
Rack
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
20"
Height (Rack Units)
8U
53.5 cm
51 cm
49.5 cm
10.8 kg
Weight Limit
80 kg
Adjustable depth
UL, RoHS
Limited warranty: - lifetime
7P1F StarTech.com 8U Open Frame Wall Mount Equipment Rack - 12in Deep In Stock £71.12
7P1F StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £31.00
7P1F StarTech.com Black Standard Universal Server Rack Cabinet Shelf In Stock £31.59
7P1F StarTech.com 50 Pkg M6 Cage Nuts for Server Rack Cabinet In Stock £14.45
7P1F StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £29.01
7P1F StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.95
7P1F StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £58.14
7P1F StarTech.com 24 Port 0.5U Cat5e Patch Panel - RJ45 Ethernet Rackmount Cat 5e 110 Patch Panel In Stock £33.73
7P1F StarTech.com 12U 22in Depth Hinged Open Frame Wall Mount Server Rack In Stock £248.23
7P1F StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.36
7P1F StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £7.19
7P1F StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £40.06
7P1F StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.73
7P1F StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £57.99
7P1F StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.93
7P1F StarTech.com 100 Pkg M5 Cage Nuts In Stock £26.80
7P1F StarTech.com 100 Pkg M5 Cage Nuts In Stock £28.99
7P1F StarTech.com 100 Pkg M6 Cage Nuts In Stock £26.73
7P1F StarTech.com 100 Pkg M6 Cage Nuts In Stock £28.49
7P1F StarTech.com 19in Cable Management Panel In Stock £23.30
7P1F StarTech.com 15U Wall-Mount Server Rack In Stock £121.49
7P1F StarTech.com 12U Wall-Mount Server Rack In Stock £106.55
7P1F StarTech.com M6 Mounting Screws 50Pack In Stock £17.93
7P1F StarTech.com 24U Open Frame Equipment Rack In Stock £191.46
Type: Wall Mount
Depth (mm): 51cm
Width (mm): 53.5cm
U Height: 8U
