StarTech.com 8U 22in Depth Hinged Open Frame Wall Mount Server Rack
Quicklinx: 8G5KWS00 Mfr#: RK819WALLOH
U Height: 8U
Width (mm): 60.4cm
Depth (mm): 55.5cm
Type: Wall Mount
£227.29 ex VAT
£272.74 inc VAT
Wall-mount your server or networking equipment with a hinged rack design for easy access and maintenance. The RK819WALLOH 8U 22in Depth Hinged Open Frame Wall Mount Server Rack lets you wall mount your (19-inch wide) servers, A/V or network equipment and features a hinged rack design that allows the entire frame to swing open for easy installation and maintenance of your equipment.
The 8U wallmount rack offers a 4 post design for additional support of your equipment, storing a maximum weight capacity of 63 kg (140 lbs). Constructed of high-quality SPCC cold-rolled steel for strength and durability, the open frame wallmount server rack allows for maximum airflow, and ships complete with all of the rack screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com "8U Hinged Open Frame Wall Mount Network Rack - 4-Post 22"" Depth Swing Out Computer Equipment Rack - 140lbs capacity (RK819WALLOH)" - rack - 8U
Rack
Placing / Mounting
Wall mountable
Rack Size
22"
Height (Rack Units)
8U
Product Material
Cold-rolled steel
60.4 cm x 55.5 cm x 48.8 cm
15.1 kg
Hinged
Rack
Placing / Mounting
Wall mountable
Product Material
Cold-rolled steel
Rack Size
22"
Height (Rack Units)
8U
60.4 cm
55.5 cm
48.8 cm
15.1 kg
Weight Limit
63.4 kg
Mounting Kit
Included
Hinged
EIA-310-D, UL, RoHS
Limited warranty: - lifetime
8G5K StarTech.com 50 Pkg M5 Cage Nuts for Server Rack Cabinets In Stock £12.20
8G5K StarTech.com 50 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £30.66
8G5K StarTech.com 50 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £28.24
8G5K StarTech.com 100 Pkg M5 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £54.39
8G5K StarTech.com 100 Pkg M6 Mounting Screws and Cage Nuts for Server Rack Cabinet In Stock £57.53
8G5K StarTech.com 8U Open Frame Wall Mount Equipment Rack - Adjustable Depth In Stock £133.04
8G5K StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x3.9in (5.7x10cm) In Stock £3.06
8G5K StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 1.8x3.9in (4.5x10cm) In Stock £4.68
8G5K StarTech.com Multi-Directional Vertical Server Rack Cable Management D-Ring Hook 2.4x3.9in (6x10cm) In Stock £6.36
8G5K StarTech.com 1U Brush Strip Horizontal Server Rack Cable Management Panel In Stock £38.59
8G5K StarTech.com 24 Port 1U Rackmount Cat 6 110 Patch Panel In Stock £47.16
8G5K StarTech.com 1U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £17.75
8G5K StarTech.com 2U Horizontal Finger Duct Rack Cable Management Panel with Cover In Stock £23.11
8G5K StarTech.com 100 Pkg M6 Screws & Cage Nuts In Stock £56.58
8G5K StarTech.com 50 Pkg M6 Screws & Cage Nuts In Stock £30.63
8G5K StarTech.com 50 Pkg M6 Cage Nuts In Stock £20.19
8G5K StarTech.com 100 Pkg M5 Cage Nuts In Stock £9.55
8G5K StarTech.com 50 Pkg M5 Cage Nuts In Stock £5.39
8G5K StarTech.com 100 Pkg M5 Screws & Cage Nuts In Stock £53.55
8G5K StarTech.com 50 Pkg M5 Screws & Cage Nuts In Stock £28.25
8G5K StarTech.com 100 Pkg M5 Mounting Screws In Stock £29.69
8G5K StarTech.com 50 Pkg M6 Mounting Screws In Stock £16.56
8G5K StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.01
8G5K StarTech.com 100 Pkg M6 Cage Nuts In Stock £27.11
8G5K StarTech.com 19in Cable Management Panel In Stock £24.18
8G5K StarTech.com 9U Wall-Mount Rack - Open Frame - 2 Post - 18 in. Deep In Stock £148.17
8G5K StarTech.com 6U Wall-mount Rack - Open Frame - 2 Post - 18 in. Deep - 175lb. Weight Capacity In Stock £113.53
8G5K StarTech.com M6 Mounting Screws 50Pack In Stock £16.56
U Height: 8U
Width (mm): 60.4cm
Depth (mm): 55.5cm
Type: Wall Mount
