StarTech.com 8K HDMI Switch, 8K 60Hz
Quicklinx: H2TJWS00 Mfr#: 4PORT-8K-HDMI-SWITCH
11 In Stock
£62.43 ex VAT
£74.91 inc VAT
  • 8K 60Hz Resolution
    The HDMI Switcher supports resolutions of up to 8K 60Hz. In addition, it supports lower resolutions at higher refresh rates, such as 4K 144Hz, 4K 120Hz, and 1080p 240Hz. This Video Switch is HDMI 2.1 complaint and supports features such as Variable Refresh Rate (VRR), Auto Low-Latency Mode (ALLM), and Consumer Electronics Control (CEC). It is backwards compatible with HDMI 2.0 (and lower) devices.
  • Automatic or Manual Operation
    The 8K Video Switch features three options for selecting the source device. Automatic mode detects and selects the most recently activated source device or it will revert to the last active source device. Manual mode selects the desired port, using the push buttons, or with the included remote control (batteries not included). The remote control can enable or disable the automatic switching mode and it can disable the IR functionality.
  • Flexible Installation Options
    Use the included USB wall charger and 2.5ft (78cm) USB Micro-B cable to power the unit. If a wall outlet is unavailable, the 8K Switch can be powered through a 5V 1A USB port as well. The included mounting kit and rubber feet enable versatile installation options. The metal housing enhances durability, making it suitable for installation and use in a variety of environments. This product is backed for 2-years by StarTech.com, including free 24/5 multi-lingual technical assistance.
StarTech.com 4-Port 8K HDMI Switch, HDMI 2.1 Switcher 4K 120Hz HDR10+, 8K 60Hz UHD, HDMI Switch 4 In 1 Out, Auto/Manual Source Switching, Remote Control and Power Adapter Included - 7.1 Channel Audio/eARC (4PORT-8K-HDMI-SWITCH) - video/audio switch - 4 ports
Video/audio switch - 4 ports
Subtype
HDMI
Ports
4 x HDMI
Performance
Bandwidth: 48 Gbps
7.1 channel audio support, metal housing, Dolby TrueHD support, DTS-HD Master Audio support, Dolby Atmos support, DTS:X support, auto-switching, HDR10+ support, push button, VRR, ALLM
HDCP 1.4, HDCP 2.2, HDCP 2.3
AC 100-240 V 0.3 A
13.6 cm x 6.1 cm x 1.4 cm
150 g
Enclosure Type
Desktop
Subtype
HDMI
Ports
4 x HDMI
Performance
Bandwidth: 48 Gbps
Max Resolution
8K @ 60 Hz
Status Indicators
Port status, power, auto, infrared
4 x HDMI input Type A , 1 x HDMI output Type A , 1 x micro-USB (power only) Type B
External power adapter
Power Provided
DC 5 V - 1 A
AC 100-240 V
Electric Current Required
0.3 A
5 Watt
Remote control, 4 rubber feet, mounting kit
1 x USB-A to Micro-USB Type B cable - 78 cm
RoHS, WEEE, CEC, RCM
13.6 cm
6.1 cm
1.4 cm
150 g
Shipping Width
17.9 cm
Shipping Depth
12.3 cm
Shipping Height
5 cm
Shipping Weight
420 g
Limited warranty - 2 years , Technical support - assistance - lifetime
70 °C
5 - 90% RH (non-condensing)
Min Storage Temperature
-10 °C
Max Storage Temperature
80 °C
H2TJ StarTech.com 3ft (1m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £16.48
H2TJ StarTech.com 6ft (2m) HDMI 2.1 Cable 8K - Certified Ultra High Speed HDMI In Stock £20.48
H2TJ StarTech.com 10ft Ultra High Speed HDMI 2.1 In Stock £23.74
H2TJ StarTech.com 16ft Ultra High Speed HDMI 2.1 In Stock £39.48
H2TJ StarTech.com 12ft Ultra High Speed HDMI 2.1 In Stock £33.33
H2TJ StarTech.com 2-Port 8K 60Hz HDMI Switch In Stock £43.06
