StarTech.com 8K 60Hz HDMI Signal Booster
Quicklinx: HFNNWS00 Mfr#: 33FT-8K-HDMI-BOOSTER
£77.10 ex VAT
£92.52 inc VAT
Combine two HDMI 2.1 cables into one extra-long 33ft (10m) cable, using this HDMI Signal Booster. Connect a DSC-enabled source and display for resolutions of up to 8K at 60Hz.
  • Maintain 8K 60Hz Video
    Extend an 8K 60Hz HDMI signal over existing HDMI cabling at up to 33ft (10m). It supports lower resolutions at longer distances, such as 4K 60Hz at 83ft (25m). This HDMI 2.1 compliant device supports CEC, HDR10, HDCP, DSC, and 7.1ch audio.
  • Hassle-Free Installation
    The TAA-Compliant HDMI signal amplifier requires no drivers or software. Its compact form factor and metal enclosure make it suitable for installation in a variety of environments. An included 5ft (152cm) USB Type-A power cable is provided to connect to an available USB port or USB wall charger, if required.
StarTech.com 33ft (10m) 8K 60Hz HDMI Signal Booster, Active HDMI 2.1 Inline Repeater and Video Signal Amplifier up to 8K 60Hz/4K 144Hz, Compact HDMI Cable Extender - HDMI Signal Extension (33FT-8K-HDMI-BOOSTER) - video/audio extender - HDMI - TAA Compliant
Video/audio extender (transmitter)
Ports Qty
2
External
Data Transfer Rate
48 Gbps
HDMI
Max Transfer Distance
10 m
4.6 cm x 4.9 cm x 1.6 cm
57 g
TAA Compliant
External
Ports Qty
2
Wired
HDMI
Data Transfer Rate
48 Gbps
Max Resolution
7680 x 4320
10 m
Status Indicators
7.1 channel audio support, USB powered
1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female
USB power cable
1 x micro-USB cable
HDCP 1.4, HDCP 2.2, HDCP 2.3, DSC 1.1, DSC 1.2a, RoHS, REACH, WEEE, FCC Part 15
TAA Compliant
4.6 cm
4.9 cm
1.6 cm
57 g
Shipping Width
15.9 cm
Shipping Depth
10 cm
Shipping Height
4.5 cm
Shipping Weight
200 g
0 - 80% RH
HFNN StarTech.com USB Wall Charger 17W / 3.4A x2 In Stock £15.90
HFNN StarTech.com 16ft Ultra High Speed HDMI 2.1 In Stock £39.48
HFNN StarTech.com 2-Port 8K 60Hz HDMI Switch In Stock £43.06
HFNN StarTech.com 8K HDMI Switch, 8K 60Hz In Stock £62.43
HFNN StarTech.com Active Optical HDMI 2.1 Cable 30ft In Stock £141.74
