Combine two HDMI 2.1 cables into one extra-long 33ft (10m) cable, using this HDMI Signal Booster. Connect a DSC-enabled source and display for resolutions of up to 8K at 60Hz.
Maintain 8K 60Hz Video
Extend an 8K 60Hz HDMI signal over existing HDMI cabling at up to 33ft (10m). It supports lower resolutions at longer distances, such as 4K 60Hz at 83ft (25m). This HDMI 2.1 compliant device supports CEC, HDR10, HDCP, DSC, and 7.1ch audio. -
Hassle-Free Installation
The TAA-Compliant HDMI signal amplifier requires no drivers or software. Its compact form factor and metal enclosure make it suitable for installation in a variety of environments. An included 5ft (152cm) USB Type-A power cable is provided to connect to an available USB port or USB wall charger, if required.
- StarTech.com 33ft (10m) 8K 60Hz HDMI Signal Booster, Active HDMI 2.1 Inline Repeater and Video Signal Amplifier up to 8K 60Hz/4K 144Hz, Compact HDMI Cable Extender - HDMI Signal Extension (33FT-8K-HDMI-BOOSTER) - video/audio extender - HDMI - TAA Compliant
- Video/audio extender (transmitter)
- Ports Qty
- 2
- Form Factor
- External
- Data Transfer Rate
- 48 Gbps
- Data Link Protocol
- HDMI
- Max Transfer Distance
- 10 m
- 4.6 cm x 4.9 cm x 1.6 cm
- 57 g
- TAA Compliant
- 2-year warranty
- Form Factor
- External
- Black
- Ports Qty
- 2
- Connectivity Technology
- Wired
- HDMI
- 48 Gbps
- Max Resolution
- 7680 x 4320
- 10 m
- Status Indicators
- Power
- 7.1 channel audio support, USB powered
- 1 x HDMI (input) - 19 pin HDMI Type A female , 1 x HDMI (output) - 19 pin HDMI Type A female
- Included Accessories
- USB power cable
- Cables Included
- 1 x micro-USB cable
- HDCP 1.4, HDCP 2.2, HDCP 2.3, DSC 1.1, DSC 1.2a, RoHS, REACH, WEEE, FCC Part 15
- TAA Compliant
- 4.6 cm
- 4.9 cm
- 1.6 cm
- 57 g
- Shipping Width
- 15.9 cm
- Shipping Depth
- 10 cm
- Shipping Height
- 4.5 cm
- Shipping Weight
- 200 g
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 80% RH
StarTech.com USB Wall Charger 17W / 3.4A x2 | In Stock | £17.44 |
StarTech.com 16ft Ultra High Speed HDMI 2.1 | In Stock | £39.85 |
StarTech.com 2-Port 8K 60Hz HDMI Switch | In Stock | £44.14 |
StarTech.com 8K HDMI Switch, 8K 60Hz | In Stock | £63.98 |
StarTech.com Active Optical HDMI 2.1 Cable 30ft | In Stock | £145.29 |
