StarTech.com 8in SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 7RXJWS00 Mfr#: SATA8RA1
Length: 20.3cm
Type: SATA
22 in stock
£3.35 ex VAT
£4.02 inc VAT
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATA8RA1 Right Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a right-angled SATA receptacle, providing a simple 8-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The right-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 8in Left Angle SATA cable (SATA8LA1), which provides the same simple installation as this right angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
StarTech.com 8in SATA to Right Angle SATA Serial ATA Cable - 8in SATA Cable - 8 SATA Cable - right angle SATA Cable - SATA cable - 20.3 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Shielded
Right-angled connector
Length
20.3 cm
Connector
7 pin Serial ATA - receptacle
Connector (Second End)
Red
P/N: USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Shielded
Shielding Material
American Wire Gauge (AWG)
26
Length
20.3 cm
Red
Connector
RoHS
7RXJ StarTech.com 8in SATA Serial ATA Cable In Stock £3.15
7RXJ StarTech.com 8in Latching SATA to SATA Cable - F/F In Stock £3.42
7RXJ StarTech.com 8in SATA to Right Angle SATA Serial ATA Cable In Stock £3.35
Length: 20.3cm
Type: SATA
Price Range Ex VAT: 0 - 50
