StarTech.com 8in SATA Serial ATA Cable
Quicklinx: 76PVWS00 Mfr#: SATA8
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA8 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 8in SATA Serial ATA Cable - SATA cable - Serial ATA 150/300 - SATA (F) to SATA (F) - 8 in - red - SATA8 - SATA cable - 20.3 cm
SATA cable
Interface Speed
Serial ATA 150/300
Length
20.3 cm
Connector
7 pin Serial ATA - female
Connector (Second End)
Red
P/N: 10P6G-PCIE-SATA-CARD, 2P6G-PCIE-SATA-CARD, 4P6G-PCIE-SATA-CARD, 6P6G-PCIE-SATA-CARD, SATBP125VP, USB2SATAIDE, USB3SSATAIDE
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Shielding Material
PVC
American Wire Gauge (AWG)
26
Length
20.3 cm
Red
Connector
RoHS
76PV StarTech.com 24" Serial ATA Cable In Stock £5.28
76PV StarTech.com 18in SATA Serial ATA Cable In Stock £2.50
76PV StarTech.com 12in Latching SATA Cable In Stock £6.16
76PV StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable In Stock £4.98
76PV StarTech.com 6in SATA Serial ATA Cable In Stock £3.61
76PV StarTech.com 12in SATA Serial ATA Cable In Stock £5.00
