Connect one VGA monitor and one DVI monitor to your DMS / LFH graphics card. This DMS 59 to DVI and VGA Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro cards into one DVI-I dual link female connector and one high density DB15 female connector, letting you to connect one VGA monitor and one DVI monitor for a cost-effective dual display solution.
 - StarTech.com DMS 59 Splitter Cable - 8in - DMS 59 to 1 x DVI / 1 x VGA - Y Cable - DMS 59 to VGA - Monitor Splitter Cable - DMS 59 Cable (DMSDVIVGA1) - display cable - 20 cm
 - Display cable - dual link
- Length
 - 20 cm
- Connectors
 - DMS-59 - male
- Connectors (Second End)
 - HD-15 (VGA) - female , DVI-I - female
 - RoHS
 - Black
 - Limited lifetime warranty
 - Display cable
- TMDS Links
 - Dual link
- Length
 - 20 cm
 - Black
- Connectors
 - DMS-59 - male
 - 15 pin HD D-Sub (HD-15) - female , 24+5 pin combined DVI - female
 - RoHS
                        StarTech.com 1 ft VGA to 2x VGA Video Splitter Cable – M/F | In Stock | £13.37 |
                        StarTech.com 8in LFH 59 Male to Dual Female DisplayPort DMS 59 Cable | In Stock | £16.01 |
