StarTech.com 8in LFH 59 Male to Dual Female VGA DMS 59 Cable
Quicklinx: 67B0WS00 Mfr#: DMSVGAVGA1
Type: VGA
Length: 20cm
£7.14 ex VAT
£8.56 inc VAT
Connect two VGA monitors to your DMS / LFH graphics card. This DMS 59 to dual VGA Y cable allows you to break out one LFH 59 or LFH 60 (DMS 59 and DMS 60) connection on Matrox Qid, nVidia Quadro, and PNY Quadro graphics cards into two high density DB15 female connectors, letting you connect two VGA monitors for a cost-effective dual monitor solution.
StarTech.com DMS 59 to VGA Splitter - 8in - DMS 59 to 2x VGA - Y Cable - Monitor Splitter Cable - DMS 59 Cable - DMS 59 to VGA Adapter (DMSVGAVGA1) - VGA cable - 20 cm
VGA cable
Length
20 cm
Connector
2 x HD-15 (VGA) - female
Connector (Second End)
DMS-59 - male
RoHS
VGA cable
Length
20 cm
Connector
2 x 15 pin HD D-Sub (HD-15) - female
DMS-59 - male
RoHS
Type: VGA
Length: 20cm
