Connect two DisplayPort monitors to your DMS / LFH-equipped graphics card. TheDMSDPDP1DMS-59 to Dual DisplayPortCable allows you to split the video from a single LHF graphics card on to two DisplayPort (DP) monitors.
The DMS to DP Y cable supports high resolutions of up to 4k x 2k (3840 x 2160) with a maximum HBR2 bandwidth of 21.6 Gbps and iscompatible with DMS / LFH 59or DMS / LFH 60graphics cards such as Matrox, NVIDIA, PNY, ATI and HP.
The DMSDPDP1 is designed and constructed for maximum durability - making it a reliable and cost-effective replacement for damaged or misplaced DMS to 2x DisplayPortcables.
- StarTech DMS-59 to DisplayPort - 8in - DMS 59 to 2x DP - Y Cable - DMS-59 Adapter - DisplayPort Splitter Cable - LFH Cable (DMSDPDP1) - display splitter - 20.3 cm
- Display splitter
- Molded, thumbscrews, strain relief
- Cable Length
- 20.3 cm
- Connector
- 2 x DisplayPort - female
- Connector (Second End)
- DMS-59 - male
- RoHS
- Black
- Limited lifetime warranty
- Display splitter
- Shielding Material
- Aluminum mylar foil with braid
- American Wire Gauge (AWG)
- 32
- Plated Connector
- Nickel
- Cable Length
- 20.3 cm
- Black
- Connector
- 2 x 20 pin DisplayPort - female
- DMS-59 - male
- RoHS
