Connect a DVI-D device to an HDMI-enabled device using a standard HDMI cable. The HDDVIMF8IN HDMI to DVI Cable Adapter features one HDMI male connector and one DVI-D female connector, which enables a bi-directional connection between HDMI-capable devices and DVI-D capable devices to overcome compatibility issues.
The HDMI to DVI dongle offers 8-inches in cable length, which lessens strain on the connectors and prevents damage to the cable, while also reducing the potential of blocking other nearby ports.
- StarTech.com HDMI Male to DVI Female Adapter - 8in - 1080p DVI-D Gender Changer Cable (HDDVIMF8IN) - video adapter - 20.32 cm
- Cable
- Video adapter - HDMI / DVI
- Technology
- Shielded
- American Wire Gauge (AWG)
- 28
- Length
- 20.32 cm
- Black
- Connector
- HDMI - male
- Connector (Second End)
- DVI-D - female
- Limited lifetime warranty
- Designed For
- P/N: 45PATCH25WH, BNDDKT30CAHV, CDP2DVIMM2MB, DKT30CSDHPD, DKT30CSDHPD3, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, USB31GEHD, USB3SMDOCKHV
- Cable Type
- Video adapter
- Interface Supported
- HDMI / DVI
- Technology
- Shielded
- 28
- Jacket Material
- PVC
- Shielding Material
- Aluminum mylar foil with braid
- Length
- 20.32 cm
- Plated Connector
- Gold
- Black
- Connector
- 19 pin HDMI Type A - male
- 24+1 pin digital DVI - female
- RoHS
- Limited warranty - lifetime
- Designed For
