Extend the reach of your EPS power supply cable by 8in. The EPS8EXT EPS Power Extension Cable features one female and one male 8-pin ATX 12V connector, enabling you to extend the reach of your EPS power supply cable by up to 8-inches and giving you the flexibility to custom build your PC without having to stretch or strain the cable.
- StarTech.com EPS 8 Pin Power Extension Cable - Power extension cable - 8 pin EPS12V (F) to 8 pin EPS12V (M) - 7.9 in - EPS8EXT - power extension cable - 8 pin EPS12V to 8 pin EPS12V - 20 cm
- Length
- 20 cm
- Connector
- Power 8 pin EPS12V - female
- Connector (Second End)
- Power 8 pin EPS12V - male
- Limited lifetime warranty
- Designed For
- StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
- Length
- 20 cm
- Connector
- FCC, RoHS
- Designed For
