StarTech.com 8in EPS 8 Pin Power Extension Cable
Quicklinx: 7B5GWS00 Mfr#: EPS8EXT
Length: 20cm
£4.34 ex VAT
£5.20 inc VAT
Extend the reach of your EPS power supply cable by 8in. The EPS8EXT EPS Power Extension Cable features one female and one male 8-pin ATX 12V connector, enabling you to extend the reach of your EPS power supply cable by up to 8-inches and giving you the flexibility to custom build your PC without having to stretch or strain the cable.
StarTech.com EPS 8 Pin Power Extension Cable - Power extension cable - 8 pin EPS12V (F) to 8 pin EPS12V (M) - 7.9 in - EPS8EXT - power extension cable - 8 pin EPS12V to 8 pin EPS12V - 20 cm
Length
20 cm
Connector
Power 8 pin EPS12V - female
Connector (Second End)
Power 8 pin EPS12V - male
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC
Length
20 cm
Connector
FCC, RoHS
Length: 20cm
