StarTech.com 8in 6 pin PCI Express Power Extension Cable
Quicklinx: 7P0VBTBS Mfr#: PCIEPOWEXT
Length: 20cm
Type: Power
More than 50 In Stock
£2.53 ex VAT
£3.03 inc VAT
The PCIEPOWEXT 8-inch PCI Express Power Extension Cable extends the reach of your ATX12V power supply PCIe power connector by 8 inches, making it easier to power your PCI Express based video card without having to stretch or add strain to the PCI Express power connector from the power supply.
StarTech.com 8in 6 pin PCI Express Power Extension Cable - Power extension cable - 6 pin PCIe power (M) to 6 pin PCIe power (F) - 7.9 in - black - PCIEPOWEXT - power extension cable - 6 pin PCIe power to 6 pin PCIe power - 20 cm
Length
20 cm
Connector
6 pin PCI Express power - male
Connector (Second End)
6 pin PCI Express power - female
American Wire Gauge (AWG)
18
Length
20 cm
Connector
RoHS
7P0V StarTech.com 8in ATX12V 4 Pin P4 CPU Power Extension Cable - M/F In Stock £5.00
7P0V StarTech.com 8in EPS 8 Pin Power Extension Cable In Stock £4.35
Length: 20cm
Type: Power
