The PCIEPOWEXT 8-inch PCI Express Power Extension Cable extends the reach of your ATX12V power supply PCIe power connector by 8 inches, making it easier to power your PCI Express based video card without having to stretch or add strain to the PCI Express power connector from the power supply.
- StarTech.com 8in 6 pin PCI Express Power Extension Cable - Power extension cable - 6 pin PCIe power (M) to 6 pin PCIe power (F) - 7.9 in - black - PCIEPOWEXT - power extension cable - 6 pin PCIe power to 6 pin PCIe power - 20 cm
- Length
- 20 cm
- Connector
- 6 pin PCI Express power - male
- Connector (Second End)
- 6 pin PCI Express power - female
- Black
- Limited lifetime warranty
- American Wire Gauge (AWG)
- 18
- Length
- 20 cm
- Black
- Connector
- RoHS
StarTech.com 8in ATX12V 4 Pin P4 CPU Power Extension Cable - M/F | In Stock | £5.00 |
StarTech.com 8in EPS 8 Pin Power Extension Cable | In Stock | £4.64 |
