StarTech.com 8in 24 Pin ATX 2.01 Power Extension Cable
Quicklinx: 4LRTWS00 Mfr#: ATX24POWEXT
Length: 20cm
Type: Motherboard
16 In Stock
£5.90 ex VAT
£7.08 inc VAT
Extend the length of an ATX power supply connection by up to 8in. The ATX24POWEXT ATX 2.01 Power Extension Cable features one male and one female 24-pin ATX connector, enabling you to extend the length of an ATX power supply connection.
Providing 8-inches of cable length, the ATX24POWEXT allows you to position your internal components as needed within the system case without having to strain the ATX or motherboard connections.
StarTech.com 8in 24 Pin ATX 2.01 Power Extension Cable - Power extension cable - 24 pin ATX (M) to 24 pin ATX (F) - 7.9 in - ATX24POWEXT - power extension cable - 24 pin ATX to 24 pin ATX - 20 cm
Length
20 cm
Connector
Power 24 pin ATX - male
Connector (Second End)
Power 24 pin ATX - female
Length
20 cm
Connector
FCC
Length: 20cm
Type: Motherboard
