Extend SATA Power Connections by up to 8in. The SATAPOWEXT8 8-inch, 15-Pin SATA Power Extension Cable enables you to extend the reach between internal SATA power and drive connections by up to 8 inches. The extension simplifies drive installation by overcoming typical connection limitations, and it reduces the risk of damage to the drive or motherboard SATA connectors by eliminating the need to strain or stretch the cable in order to make the necessary connection.
- StarTech.com 8in 15 pin SATA Power Extension Cable - 8 SATA power Extension Cable - 8 SATA power Extension cord - power extension cable - SATA power to SATA power - 20.3 cm
- Power extension cable
- Length
- 20.3 cm
- Connector
- 15 pin Serial ATA power - male
- Connector (Second End)
- 15 pin Serial ATA power - female
- 1-year warranty
- Designed For
- P/N: PYO2SATA, PYO4SATA, SATAPOWADAP
- Length
- 20.3 cm
- Connector
- 1-year warranty
- Designed For
StarTech.com 12in 22 Pin SATA Power and Data Extension Cable | In Stock | £6.79 |
StarTech.com 8in 15 pin SATA Power Extension Cable | In Stock | £5.56 |
StarTech.com 12in 15 pin SATA Power Extension Cable | In Stock | £8.28 |
