Proper cooling systems are arguably the most important part of a fast-running, interruption-free computer. Without adequate cooling, workstations can overheat causing CPU slowdowns and system freezes translating into downtime. Fans like the FAN478 offer great cooling at a great price. Suited for Pentium 4 environments, this super-duty Socket 478 CPU cooler keeps your computer running at optimal temperatures. The closely spaced fins of the aluminum heatsink provide increased heat dissipation, more effective than normal heatsink/fan combos.
- StarTech.com 85x70x50mm Socket 478 CPU Cooler Fan - CPU Cooler with Heatsink & TX3 Connector (FAN478) - processor cooler
- Product Type
- Processor cooler
- Compatibility
- Socket 423, Socket 478
- Heatsink Material
- Aluminium
- Fan Diameter
- 60 mm
- Fan Height
- 10 mm
- Noise Level
- 29 dB
- Power Connector
- 3-pin plug
- Ball bearing
- Product Material
- Aluminium
- 0.3 kg
- 2-year warranty
- Product Type
- Processor cooler
- Product Material
- Aluminium
- 0.3 kg
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 82 mm x 70 mm x 39 mm
- Fan Diameter
- 60 mm
- Fan Height
- 10 mm
- Noise Level
- 29 dB
- Power Connector
- 3-pin plug
- Ball bearing
- Limited warranty: - 2 years
