The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a 3-lead TX3 connector that plugs into the motherboard and allows the system to monitor fan speed and operating status.
 - StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ TX3 Connector (FANBOX2) - system fan kit
- Product Type
 - System fan kit
- Fan Diameter
 - 80 mm
- Noise Level
 - 34 dB
 - 8 cm x 2.5 cm x 8 cm
 - 75 g
 - 2-year warranty
- Product Type
 - System fan kit
 - 8 cm
 - 2.5 cm
 - 8 cm
 - 75 g
Heatsink & Fan
- Fan Diameter
 - 80 mm
- Noise Level
 - 34 dB
 - Limited warranty: - 2 years - carry-in
 - -10 °C
 - 80 °C
                        StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable | In Stock | £2.92 |
                        StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £5.94 |
                        StarTech.com Mounting PC Case Fan Screws - 50 Pack | In Stock | £2.73 |
                        StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.35 |
                        StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £7.84 |
                        StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £6.48 |
