The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a power tap that is connected to the large LP4 power connector on a PC's power supply.
 - StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - computer case Fan - 80mm Fan - pc Fan (FANBOX) - system fan kit
- Product Type
 - System fan kit
- Fan Diameter
 - 80 mm
- Noise Level
 - 27 dB
 - Ball bearing
- Product Material
 - Plastic
 - 8 cm x 2.5 cm x 8 cm
 - 75 g
 - 2-year warranty
- Product Type
 - System fan kit
- Product Material
 - Plastic
 - 8 cm
 - 2.5 cm
 - 8 cm
 - 75 g
Heatsink & Fan
- Fan Diameter
 - 80 mm
- Noise Level
 - 27 dB
 - Ball bearing
 - Limited warranty: - 2 years - carry-in
 - -10 °C
 - 80 °C
                        StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £5.94 |
                        StarTech.com Mounting PC Case Fan Screws - 50 Pack | In Stock | £2.73 |
                        StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.35 |
                        StarTech.com 120x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £7.84 |
                        StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £6.48 |
Customer reviews
Write a review for the StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector here!
Good ariflow but very noisy
Reviewed by ben. Review Posted 09/03/2008
Not a bad fan for the money. Came with screws, blows a decent breeze but it is very noisy.
                        Overall
                        Ease of use
                        Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
