StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector
Customer rating: 3.0* (Write a review)
Quicklinx: 403SWS00 Mfr#: FANBOX
£5.94 ex VAT
£7.12 inc VAT
The StarTech.com 8cm x 8cm x 2.5cm (3 1/8" x 3 1/8" x 1") PC case fan is an add-in cooling fan designed to fit most computers. It can be used to circulate cool air into the case or exhaust warm air out, preventing problems due to overheating components. A quiet running brushless ball bearing DC motor coupled with a high efficiency blade design is capable of moving 32 CFM (cubic feet per minute) of air. Power is supplied to the fan using a power tap that is connected to the large LP4 power connector on a PC's power supply.
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan w/ LP4 Connector - computer case Fan - 80mm Fan - pc Fan (FANBOX) - system fan kit
System fan kit
Fan Diameter
80 mm
Noise Level
27 dB
Ball bearing
Product Material
Plastic
8 cm x 2.5 cm x 8 cm
75 g
System fan kit
Product Material
Plastic
8 cm
2.5 cm
8 cm
75 g
Heatsink & Fan
Fan Diameter
80 mm
Noise Level
27 dB
Ball bearing
Limited warranty: - 2 years - carry-in
-10 °C
80 °C
Customer reviews
Write a review for the StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector here!
Good ariflow but very noisy
Reviewed by ben. Review Posted 09/03/2008
Not a bad fan for the money. Came with screws, blows a decent breeze but it is very noisy.
  • Overall 3*
  • Ease of use 4*
  • Value for money 4*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
