StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector
Quicklinx: 7TX7WS00 Mfr#: FAN8025PWM
Type: Case Fan
£6.59 ex VAT
£7.90 inc VAT
Add a variable speed, PWM-controlled cooling fan to a computer case. The FAN8025PWM 80mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures, to keep components running optimally.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
  • Efficient airflow
    The fan provides airflow rates between 9.74 and 25 cfm, supporting effective cooling for various case setups.
  • Quiet performance
    Operating at noise levels of 10 to 28 dBA, this fan maintains a peaceful computing environment while ensuring adequate cooling.
  • Robust temperature range
    With a minimum operating temperature of -10°C and a maximum of 70°C, this fan is designed to function effectively in diverse thermal conditions.
  • Flexible connectivity
    The included Y-Split cable allows for connecting multiple fans or provides versatility in setup options.
  • Bearing technology
    The Ever Lubricate bearing enhances the fan's lifespan and ensures smooth operation under continuous use.
StarTech.com 80x25mm Computer Case Fan with PWM - Pulse Width Modulation Connector - computer cooling Fan - 80mm Fan - pwm Fan (FAN8025PWM) - case fan
Case fan
Package Content
Y-Split cable
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2500 rpm
Air Flow
9.74-25 cfm
Noise Level
10 - 28 dBA
Power Connector
4-pin fan connector, 4 pin Molex connector
8 cm x 8 cm x 2.5 cm
86 g
Case fan
Package Content
Y-Split cable
8 cm
8 cm
2.5 cm
86 g
Heatsink & Fan
Fan Diameter
80 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-2500 rpm
Air Flow
9.74-25 cfm
Noise Level
10 - 28 dBA
Power Connector
RoHS
Limited warranty: - 2 years
-10 °C
70 °C
7TX7 StarTech.com Mounting PC Case Fan Screws - 50 Pack In Stock £3.09
7TX7 StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector In Stock £5.43
7TX7 StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M In Stock £6.52
7TX7 StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector In Stock £7.70
7TX7 StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector In Stock £6.59
7TX7 StarTech.com 6in TX3 Fan Power Splitter Cable In Stock £4.24
Type: Case Fan
