Add a variable speed, PWM-controlled cooling fan to a computer case. The FAN8025PWM 80mm PWM case fan adds an efficient air cooling solution to computer cases or other enclosures, to keep components running optimally.
With Pulse Width Modulation (PWM) technology, the fan speed can be dynamically controlled by the motherboard, so the fan runs at a speed that suits the operating conditions - lowering power consumption and fan noise when the system is idle, and delivering maximum cooling under full load conditions.
- StarTech.com 80x25mm Computer Case Fan with PWM - Pulse Width Modulation Connector - computer cooling Fan - 80mm Fan - pwm Fan (FAN8025PWM) - case fan
- Product Type
- Case fan
- Package Content
- Y-Split cable
- Black
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Ever Lubricate bearing
- Rotation Speed
- 800-2500 rpm
- Air Flow
- 9.74-25 cfm
- Noise Level
- 10 - 28 dBA
- Power Connector
- 4-pin fan connector, 4 pin Molex connector
- 8 cm x 8 cm x 2.5 cm
- 86 g
- 2-year warranty
- Product Type
- Case fan
- Package Content
- Y-Split cable
- 8 cm
- 8 cm
- 2.5 cm
- 86 g
- Black
Heatsink & Fan
- Fan Diameter
- 80 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2500 rpm
- Air Flow
- 9.74-25 cfm
- Noise Level
- 10 - 28 dBA
- Power Connector
- RoHS
- Limited warranty: - 2 years
- -10 °C
- 70 °C
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with LP4 Connector | In Stock | £6.57 |
StarTech.com 80x25mm Ball Bearing Quiet Computer Case Fan with TX3 Connector | In Stock | £6.19 |
StarTech.com Mounting PC Case Fan Screws - 50 Pack | In Stock | £2.75 |
StarTech.com 80x25mm Dual Ball Bearing Computer Case Fan with TX3 Connector | In Stock | £5.36 |
StarTech.com 12in 4 Pin Fan Power Splitter Cable - F/M | In Stock | £5.74 |
StarTech.com 120x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £8.12 |
StarTech.com 80x25mm Computer Case Fan with PWM – Pulse Width Modulation Connector | In Stock | £6.95 |
StarTech.com 6in TX3 Fan Power Splitter Cable | In Stock | £2.94 |
