Brand
StarTech.com 8-Port USB to Serial Adapter
Quicklinx: DKTSWS00 Mfr#: ICUSB234858I
Type: Serial adapter
Interface: USB 2.0
£364.64 ex VAT
£437.56 inc VAT
Add eight ports supporting three serial protocols, to easily connect serial devices to your computer through USB, with 15kV ESD protection. Add extra COM ports to your laptop or desktop computer, quickly and easily. This USB to RS232/422/485 serial adapter lets you connect to your serial devices through an external USB port.
The versatile serial adapter converts a single USB port into eight RS232/RS422/RS485 serial ports, enabling you to connect, monitor, and control a wide range of serial devices, such as sensors, barcode scanners, and LED signage. It supports four operating modes, including RS232, RS422, 4-wire and 2-wire RS485.
With its rugged IP30-rated metal hub housing, the serial adapter is built to meet the extreme demands of harsh and mission-critical environments. It provides 15 kV ESD protection, which helps to reduce downtime in industrial environments where communications lines are more prone to noise emissions or sudden spikes in voltage.
The serial adapter offers flexible mounting options, with a built-in wall-mounting bracket and included DIN rail mounting kit. It also features a screw-locking host connection plus a screw-locking USB-B connector on the included USB cable, to prevent accidental disconnections.
The serial adapter is equipped with high-speed UARTs, providing fast data rates of up to 921Kbps in RS232/422/485 operating modes.
StarTech.com 8 Port Serial Hub USB to RS232/RS485/RS422 Adapter, Industrial USB 2.0 to DB9 Serial Converter Hub, IP30 Rated, Din Rail Mountable Metal Serial Hub, 15kV ESD Protection - 6ft Locking Cable Incl (ICUSB234858I) - serial adapter - USB 2.0 - RS-232/422/485 x 8 - TAA Compliant
Serial adapter
DIN rail mountable
Interface (Bus) Type
USB 2.0
Ports
RS-232/422/485 x 8
12.8 cm x 21.9 cm x 2.5 cm
750 g
RS-232, RS-422, RS-485
Data Transfer Rate
921.6 Kbps
FTDI FT4232H
Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2008 / 2012 R2, Apple MacOS X 10.9 - 10.13, Linux 2.4.x to 4.11.x LTS versions only
TAA Compliant
Serial adapter
DIN rail mountable
USB 2.0
Ports
RS-232/422/485 x 8
Wired
Data Transfer Rate
921.6 Kbps
Status Indicators
Transmit, receive
15 KV Electrostatic Discharge Protection
Processor / Memory
FTDI FT4232H
8 x RS-232/422/485 - 9 pin D-Sub (DB-9) - male , 1 x USB - 4 pin USB Type A - female , 1 x USB - 4 pin USB Type B - female
1 x USB-A to USB-B cable (external)
FCC, RoHS, WEEE
TAA Compliant
36 Watt
12.8 cm
21.9 cm
2.5 cm
750 g
55 °C
5 - 95%
DKTS StarTech.com 1 ft USB to RS232 Serial DB9 Adapter Cable with COM Retention In Stock £19.31
DKTS StarTech.com 1 Port FTDI USB to Serial RS232 Adapter Cable with COM Retention In Stock £20.62
DKTS StarTech.com 16-Port USB-Serial Adapter Hub In Stock £405.39
DKTS StarTech.com 8 Port USB-Serial Adapter Hub In Stock £225.65
Interface: USB 2.0
Stock Status: In stock
