StarTech.com 8 Port USB+PS2 KVM Switch
Quicklinx: 3ZNNWS00 Mfr#: SV831HDGB
This hybrid KVM switch lets you control 8 USB or PS/2 computers using only one PS/2 keyboard, mouse, and monitor.
A versatile KVM solution, the switch is compatible with PC, Mac and Sun servers and systems and offers hot-pluggable operation, allowing you to add or remove computers without having to shut down the KVM switch.
Providing scalable KVM control, the USB+PS/2 switch delivers control of up to 64 computers/servers by cascading 8 additional KVM switches. Plus, the switch can be rackmounted into 1U of cabinet space and features rear panel cable connections, eliminating mess and tangle while saving valuable workspace.
StarTech.com 8 Port 1U RackMount USB PS/2 KVM Switch with OSD - KVM switch - 8 ports
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
On-Screen Display
43.6 cm x 18 cm x 4.4 cm
English / United Kingdom
3-year warranty
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
PS/2
Max Resolution
1920 x 1440
On-Screen Display
Status Indicators
Port status, power
8 x KVM / USB DB-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2)
External power adapter
DDC-2B
43.6 cm
18 cm
4.4 cm
Limited warranty - 3 years
