Enhance your StarTech.com LCD console by adding control for eight USB computers, or use with a separate USB keyboard and mouse with VGA display. This 8-port KVM module works with the StarTech.com series of rack-mounted LCD consoles, enabling you to control eight servers from one location. You can upgrade a single port LCD console or replace a faulty console.
With independent VGA and USB keyboard and mouse ports, you can also use this switch as a standalone KVM, creating a discreet rack-mountable KVM solution.
By adding this KVM module to your rack mount LCD console you can control eight individual computers or servers from a centralized location.
Because the KVM module works with your existing LCD console, you can ensure simple integration into your server room setup. To ensure compatibility this KVM module supports any operating system has been extensively tested in Windows, Mac and Linux environments.
You can also connect to USB servers using StarTech.com's convenient line of 2-in-1 USB KVM cables. The cables come in variety of lengths your specific requirements.
- StarTech.com 8-port USB KVM Module for Rack-Mount LCD Consoles with additional USB and VGA Console (CAB831HDU) - KVM switch - 8 ports - rack-mountable
- KVM switch - 8 ports - cascadable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- On-Screen Display, rugged
- Power
- AC 120/230 V
- 43.6 cm x 18 cm x 4.5 cm
- 1.4 kg
- Black
- 3-year warranty
- Designed For
- P/N: RKCONS1908K, RKCONS1916K, SVECONUS10, SVECONUS15, SVECONUS6
- Enclosure Type
- Rack-mountable 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Max Resolution
- 1920 x 1440 @ 60 Hz
- Status Indicators
- Link/activity
- 8 x KVM HD-15 , 1 x VGA HD-15 , Keyboard / mouse: 2 x USB 2.0 - 4 pin USB Type A , Keyboard / video / mouse (KVM): 1 x 36 PIN Centronics
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Black
- Rack Mounting Kit
- Included
- DDC-2B, FCC, RoHS
- 43.6 cm
- 18 cm
- 4.5 cm
- 1.4 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 0 - 80%
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 60 °C
- Designed For
StarTech.com 6 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £7.06 |
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £10.59 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £15.89 |
