StarTech.com 8 Port SATA 6Gbps PCIe Card
Quicklinx: GJJNWS00 Mfr#: 8P6G-PCIE-SATA-CARD
Type: Storage controller
HD Size: [N/A]
Power Supply: [N/A]
10 In Stock
£79.88 ex VAT
£95.85 inc VAT
SATA III (6Gbps) - PCI Express Gen 2 - PCIe x4 Slot - 2x Mini-SAS Connectors - 2x Mini-SAS to 4x-SATA Cables Included.
  • Quad Controllers to Deliver 8-Port SATA 6Gbps Performance
    Featuring four 2-Port SATA 6Gbps controllers and a PCIe-x4 MUX, this SATA card enables the connection of eight high-performance SATA 6Gbps drives with a combined total throughput of up to 16Gbps. The SATA drives are connected via two Mini-SAS ports with two included Mini-SAS to 4x-SATA adapter cables. To ensure a secure connection, each SATA port on the included cables features a locking connector, that will prevent the drive from accidental disconnection when working inside your computer case.
  • Wide Compatibility
    The PCIe MUX that's built into this controller card manages the downstream controllers, which improves motherboard compatibility by ensuring the card will work with motherboards that support bifurcation and motherboards that do not. To further improve motherboard compatibility the card does not have a built-in RAID controller, but fully supports the use of software RAID. Plus, with supports for PCIe Gen 2 and SATA III Specifications this card ensures backward compatibility with previous generations (SATA I/II, PCIe Gen 1) at lower performance. The controller card is widely supported across all popular operating system platforms including Windows (7,8,10, 11), macOS (10.10 - 11) and Linux (2.6.32 and above).
  • Hassle-Free Installation
    The SATA controller card features plug-and-play installation and can be installed in full-profile and low-profile computer systems with a full-profile bracket preinstalled, and an interchangeable low-profile (half-height) bracket included. The card also supports storage software data management systems such as Storage Spaces (Microsoft) , RAID Assistant (MacOS) and mdraid/mdadm (Linux), for hassle-free setup, partitioning and software RAID array building. 8P6G-PCIE-SATA-CARD is backed by a StarTech.com 2-year warranty and free lifetime 24/5 North American based, multi-lingual support.
StarTech.com 8 Port SATA PCIe Card, PCI Express 6Gbps SATA Expansion Card with 4 Host Controllers, SATA PCIe Controller Card, PCI-e x4 Gen 2 to SATA III Adapter Card, Drive Cables Incl. - Windows/macOS/Linux (8P6G-PCIE-SATA-CARD) - storage controller - SATA 6Gb/s / SAS 6Gb/s - PCIe 2.0 x4
Storage controller - plug-in card - low profile
Bus Type
PCIe 2.0 x4
Data Transfer Rate
6 Gbit/s
Supported Devices
Hard drive, solid state drive
Max Storage Devices Qty
8
Microsoft Windows 7 / 8 / 8.1 / 10 / 11, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.10 or later, Linux 2.6.32 or later
1.46 cm x 15 cm x 6.86 cm
75 g
Host Bus
PCIe 2.0 x4
Storage Controller
Data Transfer Rate
6 Gbit/s
Supported Devices
8
2 x SATA 6Gb/s / SAS 6Gb/s - Mini SAS (SFF-8087) (internal)
Low-profile bracket
2 x mini SAS HD to 4 x SATA HDD cable - external - 50 cm
S.M.A.R.T. support, TRIM support, 4Kn drive compatible, bootable, ATAPI support
RoHS
1.46 cm
15 cm
6.86 cm
75 g
Shipping Width
17 cm
Shipping Depth
14.2 cm
Shipping Height
3 cm
Shipping Weight
81 g
5 °C
50 °C
20 - 80%
GJJN StarTech.com 6-Port SATA PCIe Card - 6Gbps In Stock £55.31
GJJN StarTech.com 10-Port SATA PCIe Card - 6Gbps In Stock £85.59
GJJN StarTech.com SATA III RAID PCIe Card 2pt In Stock £40.79
GJJN StarTech.com SATA III PCIe Card - 2-Port In Stock £24.73
GJJN StarTech.com 4-Port SATA PCIe Card - 6Gbps In Stock £37.99
HD Size: [N/A]
Power Supply: [N/A]
