StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included)
Quicklinx: 7B7SWS00 Mfr#: SV831DUSBAU
Type: KVM / audio switch
Ports: 8
Connectivity: KVM
Hurry, only 3 left in stock!
£337.14 ex VAT
£404.56 inc VAT
Control up to 8 VGA and USB computers from a single keyboard, mouse and monitor. The SV831DUSBAU 8 Port Rack Mount USB VGA KVM Switch (with Audio Cables Included) allows you to control up to 8 USB computers using a single keyboard, mouse and monitor, and features Audio and Microphone ports to switch between audio signals as well as PC ports.
Based on a 1U rack mountable slim form factor design, this 8 Port USB KVM uses rear cable connections to maximize space efficiency. Multiple KVM units can also be connected (cascaded) together for control of up to 64 computers, ensuring a scalable KVM solution that can be expanded as necessary.
To ensure seamless operation, the switch features automatic and manual scan modes, supports both hot-key and front panel push-button switching, and features a convenient OSD (on-screen display) for added configuration options.
StarTech.com 8 Port VGA KVM Switch - 1U Rack Mount - USB VGA KVM Switch with Audio - 1920 x 1440 @60hz - KVM Video Switch (SV831DUSBAU) - KVM / audio switch - 8 ports
KVM / audio switch - 8 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM / audio
KVM Users Qty
1 local user
On-Screen Display
54 cm x 18 cm x 4.5 cm
3-year warranty
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RACKCOND17HD, RK1233BKM, RK1236BKF, RK1833BKM, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M5NA
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM / audio
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
On-Screen Display
8 x KVM HD-15 , 8 x microphone mini-jack , 8 x audio mini-jack , 1 x VGA HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x microphone mini-jack , 1 x audio mini-jack
Internal power supply
16 x audio cable - 1.8 m
Rack Mounting Kit
Included
FCC, RoHS
54 cm
18 cm
4.5 cm
Limited warranty - 3 years
5 °C
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACKCOND17HD, RK1233BKM, RK1236BKF, RK12OD, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
7B7S StarTech.com 6 ft 3.5mm Stereo Extension Audio Cable - M/F In Stock £4.91
7B7S StarTech.com 12 ft PC Speaker Extension Audio Cable In Stock £4.98
7B7S StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £10.67
7B7S StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £15.89
7B7S StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £94.48
7B7S StarTech.com 8 Port Rackmount USB VGA KVM Switch w/ Audio (Audio Cables Included) In Stock £337.14
7B7S StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £576.36
7B7S StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £319.24
7B7S StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £657.51
7B7S StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £8.00
7B7S StarTech.com DC Power Adapter - 12V, 5A In Stock £41.16
Ports: 8
Connectivity: KVM
