StarTech.com 8 Port Rackmount USB PS/2 Digital IP KVM Switch
Quicklinx: 4H21WS00 Mfr#: SV841HDIEGB
Type: KVM switch
Connectivity: KVM
Ports: 8
£724.35 ex VAT
£869.22 inc VAT
StarTech.com's SV841HDIE revolutionizes remote server management by combining our industry-leading third generation Server Remote Control technology with a proven Enterprise class digital KVM switch.
The SV841HDIE empowers you to securely manage up to eight computers remotely from almost anywhere using your LAN or the Internet. Unlike software solutions that require installation and work through your server's operating system, the SV841HDIE gives you BIOS level control and full interaction with your system's boot process. Control does not come at the expense of security: SSH tunneling, SSL encryption, RADIUS authentication, and a configurable firewall are all included to ensure that your network stays secure. With both USB and PS/2 support, this switch easily handles a mixed platform environment to provide a central point of administration for all your servers. For added flexibility you can attach your existing KVM switches to the SV841HDIE to remotely control up to 64 computers, and its standardized 1U rack-mountable metal chassis allows easy installation in your rack or cabinet.
Server Remote Control is about more than just servers. Using the Serial Remote Interface Module (RPORT) you can interact with virtually any device that uses a RS-232 serial terminal interface like routers, switches, environmental controls, alarm systems, and more. You can also use StarTech.com's 8 outlet Remote Power Module (PCM815SHNA) to power computers and equipment on an off using an interactive menu.
The SV841HDIE is the perfect solution for any organization that demands secure, flexible local and remote administration of its critical systems.
Test drive Server Remote Control with a FREE online demo.
  • Server Remote Control
    Unlike software solutions that require installation and work through your server operating system, this easy-to-configure IP KVM Switch delivers BIOS level control and full interaction with connected system boot processes over a TCP/IP connection. Users can reboot the system, access the BIOS and have full control over the keyboard and mouse as if they are on site - a cost-effective solution for outsourced server/IT hardware management and access to mission-critical corporate datacenter servers.
  • Built-in Security
    Remote Control can't come at the expense of security! This Digital IP KVM switch features built-in support for SSH tunneling, SSL encryption and RADIUS authentication, as well as a configurable firewall. Plus, access to the IP KVM web console is user ID and SSL password secured to prevent unauthorized access.
  • A Scalable IP KVM Solution
    A scalable KVM control solution, the IP KVM Switch supports up to 8 directly-connected servers or workstation computers. To create a more flexible infrastructure, the switch can be cascaded with other existing/new KVM switches for remote control of up to 64 computers from this single IP KVM unit. To provide broader control options, the IP KVM switch supports modular integration, allowing you to add capability to your existing server remote control infrastructure. Using StarTech.com's Serial Remote Control Module (RPORT) for example, you can interact with virtually any device that uses a RS-232 serial terminal interface (network routers, switches, environmental controls, alarm systems etc.). Similarly, the IP KVM switch can be connected to StarTech.com's 8 Outlet Remote Power Switch (PCM815SHNA) to power computers and equipment on and off using an interactive menu.
  • Versatile
    Designed to accommodate a wide range of operating environments, the Digital IP KVM switch is compatible with PC, Mac and Sun Servers/Systems, ensuring the flexibility needed to efficiently manage connected devices regardless of operating platform. To provide further versatility, the switch supports computers with USB or PS/2 keyboard and mouse connectors allowing a broader mix of connected computers including both legacy (PS/2) and modern (USB).
  • Rack Mounted Convenience
    To preserve valuable server room or work space, the IP KVM can be mounted into 1U of rack/cabinet space. Similarly, all external connections to the server remote control/KVM unit are located on the rear panel to eliminate cable tangles and mess.
StarTech.com 8 Port RackMount USB PS/2 Digital IP KVM Switch - KVM switch - 8 ports - rack-mountable
KVM switch - 8 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user, 1 IP user
On-Screen Display, DHCP support, ISP, VNC support, firmware upgradable
43.2 cm x 40.4 cm
4 kg
United Kingdom
1-year warranty
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
KVM IP Users Qty
1 IP user
Keyboard / Mouse Interface
PS/2
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS
Max Resolution
1920 x 1440
On-Screen Display, DHCP support, ISP, VNC support, firmware upgradable, IP-based user connection
8 x KVM HD-15 , 1 x VGA HD-15 , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x LAN RJ-45
External power adapter
Plug and Play, FCC, RoHS
United Kingdom
43.2 cm
40.4 cm
4 kg
Limited warranty - 1 year
4H21 StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.85
4H21 StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £6.40
4H21 StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable In Stock £12.96
4H21 StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.54
4H21 StarTech.com DC Power Adapter - 12V, 2A In Stock £11.96
4H21 StarTech.com DC Power Adapter - 12V, 5A In Stock £41.02
Type: KVM switch
Connectivity: KVM
Ports: 8
Price Range Ex VAT: £500 - £750
