Add eight RS-232 DB9 serial ports to your desktop computer, through two PCIe expansion card slots. This PCI express serial card, with two breakout cables, provides you with multiple ports to connect a wide variety of serial peripherals, at speeds of up to 921.4Kbps.
The PCI express serial port card makes it easy to add serial ports to connect your peripherals including printers, scanners, credit/debit card readers, PIN pads and modems, industrial controls and more. The 8 port PCIe serial card includes 2 breakout cables - each with 4 DB9 connectors.
The low profile PCIe serial card is the ideal choice for adding serial ports, even when space is at a premium. The DB9 serial card is designed to fit into small form factor and standard computer cases. The card comes pre-configured with a low-profile bracket, and includes two optional full-profile brackets, so installation is easy regardless of the case form factor.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments.
Enhanced connectivity
This 8-Port PCI Express RS232 Serial Adapter Card offers a high-performance solution for connecting a wide range of RS-232 peripherals to a PCI Express-enabled computer. It's ideal for industrial environments, POS systems, and more, providing reliable connectivity. -
Robust protection
Equipped with 15 kV ESD protection, this PCIe RS232 Serial Card ensures your connected devices are safeguarded against electrostatic discharges, offering peace of mind and enhanced durability in harsh environments. -
High-speed data processing
Featuring a 16C1050 UART with 256-byte FIFO buffer, the card supports high-speed data transmission and reduces CPU load, allowing for efficient serial communication. -
Broad compatibility
With support for Windows and Linux operating systems and including both full profile and low-profile brackets, this serial adapter card offers versatile installation options and broad compatibility with a variety of systems and applications.
- Startech 8-Port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Card, 16C1050 UART, Low Profile Serial DB9 Controller/Expansion Card, 15kV ESD Protection, Windows/Linux - Full Profile Bracket Incl - serial adapter - PCIe - RS-232 x 8 - TAA Compliant
- Serial adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- Ports
- RS-232 x 8
- 6.7 cm x 14.3 cm x 2 cm
- 120 g
- Cabling Type
- Serial RS-232
- Processor
- ASMedia ASM1083
- Yellow
- System Requirements
- Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / 7 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
- TAA Compliant
- Limited lifetime warranty
- Serial adapter
- Form Factor
- PCI Express
- Ports
- RS-232 x 8
- Connectivity Technology
- Wired
- Cabling Type
- Serial RS-232
- 16550 UART support, 256-byte FIFO
Processor / Memory
- Processor
- ASMedia ASM1083
- 8 x RS-232 - 9 pin D-Sub (DB-9)
- Included Accessories
- Full-height bracket
- FCC, RoHS, WEEE, REACH
- Yellow
- TAA Compliant
- OS Required
- 6.7 cm
- 14.3 cm
- 2 cm
- 120 g
- Shipping Width
- 29 cm
- Shipping Depth
- 19.2 cm
- Shipping Height
- 7 cm
- Shipping Weight
- 700 g
- Limited warranty - lifetime
- 0 °C
- 55 °C
- 5 - 95%
StarTech.com 2 Port PCI Express RS232 Serial Adapter Card | In Stock | £36.09 |
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD | In Stock | £155.21 |
StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo | In Stock | £33.98 |
StarTech.com Serial/Parallel PCI Card | In Stock | £20.41 |
StarTech.com 1-Prt PCI Express Serial Card | In Stock | £36.98 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £38.53 |
StarTech.com PCIe Dual Serial Port Card | In Stock | £42.80 |
