StarTech.com 8-Port PCI Express Serial Card - Low Profile PCIe
Quicklinx: FLYHWS00 Mfr#: PEX8S1050LP
Wired / Wireless: Wired
Protocol: RS-232
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Serial adapter
Hurry, only 3 left in stock!
£155.21 ex VAT
£186.25 inc VAT
Add eight RS-232 DB9 serial ports to your desktop computer, through two PCIe expansion card slots. This PCI express serial card, with two breakout cables, provides you with multiple ports to connect a wide variety of serial peripherals, at speeds of up to 921.4Kbps.
The PCI express serial port card makes it easy to add serial ports to connect your peripherals including printers, scanners, credit/debit card readers, PIN pads and modems, industrial controls and more. The 8 port PCIe serial card includes 2 breakout cables - each with 4 DB9 connectors.
The low profile PCIe serial card is the ideal choice for adding serial ports, even when space is at a premium. The DB9 serial card is designed to fit into small form factor and standard computer cases. The card comes pre-configured with a low-profile bracket, and includes two optional full-profile brackets, so installation is easy regardless of the case form factor.
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments.
  • Enhanced connectivity
    This 8-Port PCI Express RS232 Serial Adapter Card offers a high-performance solution for connecting a wide range of RS-232 peripherals to a PCI Express-enabled computer. It's ideal for industrial environments, POS systems, and more, providing reliable connectivity.
  • Robust protection
    Equipped with 15 kV ESD protection, this PCIe RS232 Serial Card ensures your connected devices are safeguarded against electrostatic discharges, offering peace of mind and enhanced durability in harsh environments.
  • High-speed data processing
    Featuring a 16C1050 UART with 256-byte FIFO buffer, the card supports high-speed data transmission and reduces CPU load, allowing for efficient serial communication.
  • Broad compatibility
    With support for Windows and Linux operating systems and including both full profile and low-profile brackets, this serial adapter card offers versatile installation options and broad compatibility with a variety of systems and applications.
Startech 8-Port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Card, 16C1050 UART, Low Profile Serial DB9 Controller/Expansion Card, 15kV ESD Protection, Windows/Linux - Full Profile Bracket Incl - serial adapter - PCIe - RS-232 x 8 - TAA Compliant
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 8
6.7 cm x 14.3 cm x 2 cm
120 g
Cabling Type
Serial RS-232
ASMedia ASM1083
Yellow
Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / 7 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
TAA Compliant
Serial adapter
PCI Express
Ports
RS-232 x 8
Wired
Cabling Type
Serial RS-232
16550 UART support, 256-byte FIFO
Processor / Memory
ASMedia ASM1083
8 x RS-232 - 9 pin D-Sub (DB-9)
Full-height bracket
FCC, RoHS, WEEE, REACH
Yellow
TAA Compliant
6.7 cm
14.3 cm
2 cm
120 g
Shipping Width
29 cm
Shipping Depth
19.2 cm
Shipping Height
7 cm
Shipping Weight
700 g
Limited warranty - lifetime
55 °C
5 - 95%
FLYH StarTech.com 2 Port PCI Express RS232 Serial Adapter Card In Stock £36.05
FLYH StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD In Stock £155.21
FLYH StarTech.com PCIe Card with Serial and Parallel Port - PCI Express Combo In Stock £33.98
FLYH StarTech.com Serial/Parallel PCI Card In Stock £20.41
FLYH StarTech.com 1-Prt PCI Express Serial Card In Stock £36.98
FLYH StarTech.com PCIe Dual Serial Port Card In Stock £38.53
FLYH StarTech.com PCIe Dual Serial Port Card In Stock £42.80
Protocol: RS-232
