StarTech.com 8-Port PCI Express RS232 Serial Adapter Card - PCIe - 15kV ESD
Quicklinx: G11FWS00 Mfr#: PEX8S1050
Type: Serial adapter
Compatibility: PC
Interface: PCI Express
£158.99 ex VAT
£190.78 inc VAT
8-Port PCI-Express DB9 RS-232 16C1050 UART 15kV ESD Protection. Add eight RS-232 DB9 serial ports to your desktop computer, through a PCIe expansion card slots. This PCI express serial card, with 8-port breakout cable, provides you with multiple ports to connect a wide variety of serial peripherals, at speeds of up to 921.4Kbps.
Connect your Peripherals with 8 Serial Ports
The PCI express serial port card makes it easy to add serial ports to connect your peripherals including printers, scanners, credit/debit card readers, PIN pads and modems, industrial controls and more. The 8 port PCIe serial card includes a breakout cable - with 8 DB9 connectors.
Maximum Compatibility
With broad OS support, including for Windows and Linux, this PCI Express card is easy to integrate into mixed environments.
PEX8S1050 is backed by a StarTech.com lifetime warranty and free lifetime technical support.
  • Connect your peripherals with 8 serial ports
  • Maximum compatibility
StarTech.com 8-Port PCI Express RS232 Serial Adapter Card, PCIe RS232 Serial Card, 16C1050 UART, Multiport Serial DB9 Controller/Expansion Card, 15kV ESD Protection, Windows & Linux - Up to 921.6 Kbps Baud - serial adapter - PCIe - RS-232 x 8 - TAA Compliant
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express
PCI Specification Revision
PCIe 1.1
Ports
RS-232 x 8
1.6 cm x 10.5 cm x 12 cm
74 g
Cabling Type
Serial RS-232
ASMedia ASM1083
Yellow
Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / 7 / 8.1 / 10, Microsoft Windows Server 2016, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019
TAA Compliant
Serial adapter
Plug-in card
PCI Express
PCIe 1.1
Ports
RS-232 x 8
Wired
Cabling Type
Serial RS-232
Flow control, 16550 UART support, 256-byte FIFO, 1.5KV ESD Protector
Processor / Memory
ASMedia ASM1083
8 x RS-232 - 9 pin D-Sub (DB-9)
8 x hex nuts
1 x DB-62 to DB-9 breakout cable - 48 cm
MTBF
160,013 hours
RoHS, WEEE
Yellow
TAA Compliant
1.6 cm
10.5 cm
12 cm
74 g
Shipping Width
19 cm
Shipping Depth
2.9 cm
Shipping Height
6.5 cm
Shipping Weight
700 g
Limited warranty - lifetime
55 °C
5 - 95%
G11F StarTech.com 2m Black DB9 RS232 Serial Null Modem Cable F/M In Stock £4.57
Compatibility: PC
