StarTech.com 8 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART
Quicklinx: 67CRWS00 Mfr#: PEX8S952
Type: Serial adapter
Compatibility: Mac, PC
Interface: PCI Express x1
More than 50 in stock
£126.12 ex VAT
£151.34 inc VAT
This PCI Express based serial adapter card allows you to turn a PCI Express slot into eight RS232 (DB9) serial connections. The adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe) - providing optimum reliability and speed, and reducing the load applied to the CPU by as much as 48% over conventional serial cards. The RS232 Serial Adapter Card is compatible with a broad range of operating systems, including Windows 2000/XP/2003/Vista, Linux Kernel 2.6.11 and up, as well as MAC OS 10.4 and above.
StarTech.com 8 Port Native PCI Express RS232 Serial Adapter Card with 16950 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
RS-232 x 8
2 cm x 9 cm x 6.5 cm
58 g
RS-232
Microsoft Windows 98 Second Edition, Microsoft Windows XP Embedded, Microsoft Windows Server 2003, Microsoft Windows CE 5.0, Microsoft Windows CE 4.2, Microsoft Windows Server 2008 R2, Microsoft Windows CE 6.0, Microsoft Windows Server 2012, Microsoft Windows 2000 / ME / XP, Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Linux 3.5.x - 4.11.x LTS versions only
Serial adapter
Plug-in card
PCI Express x1
Ports
RS-232 x 8
Wired
RS-232
Software flow control, hardware flow control
8 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express x1
FCC, RoHS
2 cm
9 cm
6.5 cm
58 g
Limited warranty - lifetime
67CR StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £3.81
67CR StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.27
67CR StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £3.65
67CR StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £3.51
67CR StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.18
67CR StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.08
Compatibility: Mac
Compatibility: PC
Price Range Ex VAT: 100 - 150
