StarTech.com 8 Port KVM Console for Server Rack - 19in
Quicklinx: DKZYWS00 Mfr#: RKCONS1908K
Product Type: Rack, Rack
Hurry, only 1 left in stock!
£1,162.96 ex VAT
£1,395.55 inc VAT
This rack-mount KVM console provides complete keyboard, monitor and mouse control for eight computers. The rack-mount console installs into 1U of rack space, offering a space-efficient solution for complete console control.
  • Maximize your IT budget, minimize your hassle
    This 8-port KVM switch provides all the essential controls you'll need to manage your server room at a low cost. The console features a built-in touchpad, keyboard for intuitive control and an LCD display.
  • Maximize your screen space
    This versatile LCD console has a 19" screen. The increased screen space allows you to run multiple applications on the same screen, increasing your productivity.
  • Clutter-free monitoring
    The console slides out from 1U of rack space, enabling you to easily monitor and control eight servers and even more if connecting through a KVM switch. The rackmount VGA console features a handle for easy sliding in and out of the server rack, keeping your area organized and clutter free.
  • Hassle-free system integration
    The rackmount LCD features an 8-port KVM module, which enables you to connect it directly to eight servers. You can also connect to additional servers by connecting to KVM switches in a cascaded (daisy-chained) configuration.
StarTech.com 8 Port Rackmount KVM Console with 6ft Cables, Integrated KVM Switch with 19" LCD Monitor, Fully Featured 1U LCD KVM Drawer- OSD KVM, Durable 50,000 MTBF, USB + VGA Support - 19in. LCD KVM Console (RKCONS1908K) - KVM console - 19"
KVM console - 19"
KVM Switch
PS/2, USB - 8 ports
Keyboard Layout
US - English (QWERTY)
Daisy Chaining
Keyboard, touchpad, 8 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
16.7 million colours
Input Connectors
VGA
48.3 cm x 64.3 cm x 4.3 cm
Height (Rack Units)
1U
13.5 kg
Australia, Japan, New Zealand, North America, United Kingdom, Europe
UL, FCC, RoHS, WEEE, PSE Mark, RCM
Display Type
KVM console / TFT active matrix
Diagonal Size
19"
Daisy Chaining
Built-in Devices
8 port KVM switch
Aspect Ratio
5:4
Native Resolution
1280 x 1024
Pixel Pitch
0.264 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Height (Rack Units)
1U
13.5 kg
Input
Keyboard, touchpad
KVM
KVM switch - 8 ports
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1280 x 1024
2 x VGA , 2 x USB 2.0 , 8 x KVM , 2 x PS/2
8 x M5 cage nuts, 8 x M5 screws, 4 x mounting rails
8 x keyboard / mouse / video cable
Rack Mounting Kit
Included
MTBF
50,000 hour(s)
DKZY StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
DKZY StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
DKZY StarTech.com 8 Port KVM Console for Server Rack - 19in In Stock £1,162.96
DKZY StarTech.com Single Server KVM Console for Server Rack -19" In Stock £749.12
DKZY StarTech.com 16 port KVM VGA Console with KVM Switch - 19" In Stock £1,320.56
DKZY StarTech.com Single Port Server KVM console with KVM Switch In Stock £655.56
DKZY StarTech.com 17" Dual Rail Rackmount KVM Console with 1080p In Stock £927.37
DKZY StarTech.com Rackmount KVM Console - 8 Ports with 17" LCD Monitor In Stock £999.35
DKZY StarTech.com Rackmount KVM Console - 16 Ports with 17" LCD Monitor In Stock £1,151.88
DKZY StarTech.com 1U HD Single Server KVM In Stock £803.46
DKZY StarTech.com 10 ft. (3 m) USB KVM Cable for Rackmount Consoles In Stock £30.11
DKZY StarTech.com 15 ft. (4.6 m) USB KVM Cable for Rackmount Consoles In Stock £40.34
Product Type: Rack
Product Type: Rack
Price Range Ex VAT: £1000 - £1500
