StarTech.com 8-Port DisplayPort KVM Switch
Quicklinx: J4LSWS00 Mfr#: R8AD122-KVM-SWITCH
£419.56 ex VAT
£503.47 inc VAT
The 4K 60Hz rackmount KVM switch allows switching between eight DisplayPort-enabled computers, sharing a keyboard, mouse, audio, 4-port USB 2.0 hub, and a 4K 60Hz DisplayPort 1.2 monitor. This enables effortless multi-system management, improved workspace efficiency, and enhanced productivity. The TAA-Compliant 8-Port KVM Switch is universally compatible, providing BIOS-level control and working with any operating system, including Windows, Windows ARM, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms such as Intel, AMD, SnapDragon/ARM, and Apple Silicon. Ensures efficient and user-friendly operation for multi-server administration with switching via push-buttons or hotkeys, an audible buzzer for confirmation, and LEDs for quick visual port selection status. The KVM switch offers a space-saving solution for managing multiple servers directly within a rack. It includes rack-mount brackets for installation in 1U of rack space on network racks and is compatible with 19-inch server racks that have a mounting depth of 6.5 inches (165mm) or more. It also complies with ANSI/EIA RS-310-D standards.
  • No Drivers or Software
  • Multiple Switching Options
  • Rack Mount Kit Included
    The KVM switch offers a space-saving solution for managing multiple servers directly within a rack. It includes rack-mount brackets for installation in 1U of rack space on network racks and is compatible with 19-inch server racks that have a mounting depth of 6.5 inches (165mm) or more. It also complies with ANSI/EIA RS-310-D standards. To ensure flexibility to choose the best cables for your specific installation, the KVM switch does not include cables. StarTech.com offers a wide variety of DisplayPort, USB, and 3.5mm audio cables in assorted lengths to suit different installation needs.
    Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • USB Event Monitoring Utility: Track and log connected USB devices.
StarTech.com 8-Port DisplayPort KVM Switch w/1U Rack Mount Kit, 4K 60Hz - KVM switch - 8 ports - TAA Compliant
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
Pushbutton/Hotkey switching, 5.1 channel audio support, Auto Scan Mode, wide screen supported
AC 100 -240 V 1 A
16.4 cm x 30 cm x 4.4 cm
1.5 kg
Australia, Europe, New Zealand, North America, United Kingdom
TAA Compliant
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
3840 x 2160 @ 60 Hz
Status Indicators
Status
1 x DisplayPort console , 4 x USB Type A console , 1 x audio mini-jack console , 8 x DisplayPort host , 8 x USB Type B host , 8 x audio mini-jack host
External power adapter
Power Provided
3 A
AC 100 -240 V
Electric Current Required
1 A
36 Watt
Rack Mounting Kit
Included
MTBF
73,003 hours
FCC, RoHS, WEEE
TAA Compliant
16.4 cm
30 cm
4.4 cm
1.5 kg
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
J4LS StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M In Stock £3.11
J4LS StarTech.com 6 ft DisplayPort Cable with Latches - M/M In Stock £12.12
