The 4K 60Hz rackmount KVM switch allows switching between eight DisplayPort-enabled computers, sharing a keyboard, mouse, audio, 4-port USB 2.0 hub, and a 4K 60Hz DisplayPort 1.2 monitor. This enables effortless multi-system management, improved workspace efficiency, and enhanced productivity. The TAA-Compliant 8-Port KVM Switch is universally compatible, providing BIOS-level control and working with any operating system, including Windows, Windows ARM, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms such as Intel, AMD, SnapDragon/ARM, and Apple Silicon. Ensures efficient and user-friendly operation for multi-server administration with switching via push-buttons or hotkeys, an audible buzzer for confirmation, and LEDs for quick visual port selection status. The KVM switch offers a space-saving solution for managing multiple servers directly within a rack. It includes rack-mount brackets for installation in 1U of rack space on network racks and is compatible with 19-inch server racks that have a mounting depth of 6.5 inches (165mm) or more. It also complies with ANSI/EIA RS-310-D standards.
No Drivers or Software
The TAA-Compliant 8-Port KVM Switch is universally compatible, providing BIOS-level control and working with any operating system, including Windows, Windows ARM, macOS, ChromeOS, and Linux. It is also compatible with all hardware platforms such as Intel, AMD, SnapDragon/ARM, and Apple Silicon. -
Multiple Switching Options
Ensures efficient and user-friendly operation for multi-server administration with switching via push-buttons or hotkeys, an audible buzzer for confirmation, and LEDs for quick visual port selection status. -
Rack Mount Kit Included
The KVM switch offers a space-saving solution for managing multiple servers directly within a rack. It includes rack-mount brackets for installation in 1U of rack space on network racks and is compatible with 19-inch server racks that have a mounting depth of 6.5 inches (165mm) or more. It also complies with ANSI/EIA RS-310-D standards. To ensure flexibility to choose the best cables for your specific installation, the KVM switch does not include cables. StarTech.com offers a wide variety of DisplayPort, USB, and 3.5mm audio cables in assorted lengths to suit different installation needs. -
Enhance Productivity and Device Management with the StarTech.com Connectivity Tools Application
Developed to improve performance and security, StarTech.com Connectivity Tools is the only software suite on the market that works with a wide range of IT connectivity accessories. The software suite includes: • Advanced Windows Layout Utility: Setup and save custom windows layouts. • USB Event Monitoring Utility: Track and log connected USB devices.
 - StarTech.com 8-Port DisplayPort KVM Switch w/1U Rack Mount Kit, 4K 60Hz - KVM switch - 8 ports - TAA Compliant
- Enclosure Type
 - 1U
- Subtype
 - KVM
- Ports
 - 8 x KVM port(s)
- KVM Users Qty
 - 1 local user
 - Pushbutton/Hotkey switching, 5.1 channel audio support, Auto Scan Mode, wide screen supported
- Power
 - AC 100 -240 V 1 A
 - 16.4 cm x 30 cm x 4.4 cm
 - 1.5 kg
 - Black
- Localisation
 - Australia, Europe, New Zealand, North America, United Kingdom
- TAA Compliant
 - 2-year warranty
- Enclosure Type
 - Desktop 1U
- Subtype
 - KVM
- Ports
 - 8 x KVM port(s)
- KVM Local Users Qty
 - 1 local user
- Keyboard / Mouse Interface
 - USB
- Max Resolution
 - 3840 x 2160 @ 60 Hz
- Status Indicators
 - Status
 - 1 x DisplayPort console , 4 x USB Type A console , 1 x audio mini-jack console , 8 x DisplayPort host , 8 x USB Type B host , 8 x audio mini-jack host
- Power Device
 - External power adapter
- Power Provided
 - 3 A
- Voltage Required
 - AC 100 -240 V
- Electric Current Required
 - 1 A
 - 36 Watt
 - Black
- Rack Mounting Kit
 - Included
- MTBF
 - 73,003 hours
 - FCC, RoHS, WEEE
- TAA Compliant
- Localisation
 - 16.4 cm
 - 30 cm
 - 4.4 cm
 - 1.5 kg
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
- Min Storage Temperature
 - -20 °C
- Max Storage Temperature
 - 60 °C
                        StarTech.com 3 ft Slim 3.5mm Stereo Audio Cable - M/M | In Stock | £3.06 |
                        StarTech.com 6 ft DisplayPort Cable with Latches - M/M | In Stock | £11.55 |
