Manage all your computers from one convenient location with a StarTech.com KVM switch. The Startech.com SV831DUSB let you connect 8 USB or PS/2 computers using only one USB keyboard, mouse, and monitor. Convenient pushbutton and hot-key commands allow for quick, reliable switching between your systems. Manual and Auto scan modes are supported. Our slim design needs only 1U in your cabinet and uses rear cable connections for maximum space efficiency. Multiple SV831DUSB units can be cascaded to support up to 64 computers
- StarTech.com 8 Port 1U RackMount USB PS/2 KVM Switch with OSD - KVM switch - 8 ports
- KVM switch - 8 ports - cascadable
- Enclosure Type
- 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Users Qty
- 1 local user
- 43.8 cm x 18 cm x 4.5 cm
- 2.9 kg
- Localisation
- United Kingdom
- 3-year warranty
- Designed For
- P/N: RK3236BKF
- Enclosure Type
- Desktop 1U
- Subtype
- KVM
- Ports
- 8 x KVM port(s)
- KVM Local Users Qty
- 1 local user
- Keyboard / Mouse Interface
- USB
- Status Indicators
- Port status
- 8 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
- Power Device
- External power adapter
- Localisation
- United Kingdom
- 43.8 cm
- 18 cm
- 4.5 cm
- 2.9 kg
- Limited warranty - 3 years
- 5 °C
- 40 °C
- Designed For
- P/N: RK3236BKF
StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable | In Stock | £9.85 |
StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable | In Stock | £6.40 |
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable | In Stock | £12.96 |
StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD | In Stock | £268.81 |
StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable | In Stock | £7.54 |
StarTech.com DC Power Adapter - 9V, 2A | In Stock | £12.30 |
