StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD
Quicklinx: 4MHSWS00 Mfr#: SV831DUSBGB
Type: KVM switch
Connectivity: KVM
Ports: 8
£268.81 ex VAT
£322.57 inc VAT
Manage all your computers from one convenient location with a StarTech.com KVM switch. The Startech.com SV831DUSB let you connect 8 USB or PS/2 computers using only one USB keyboard, mouse, and monitor. Convenient pushbutton and hot-key commands allow for quick, reliable switching between your systems. Manual and Auto scan modes are supported. Our slim design needs only 1U in your cabinet and uses rear cable connections for maximum space efficiency. Multiple SV831DUSB units can be cascaded to support up to 64 computers
StarTech.com 8 Port 1U RackMount USB PS/2 KVM Switch with OSD - KVM switch - 8 ports
KVM switch - 8 ports - cascadable
Enclosure Type
1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
43.8 cm x 18 cm x 4.5 cm
2.9 kg
United Kingdom
3-year warranty
P/N: RK3236BKF
Enclosure Type
Desktop 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Status Indicators
Port status
8 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
United Kingdom
43.8 cm
18 cm
4.5 cm
2.9 kg
Limited warranty - 3 years
5 °C
P/N: RK3236BKF
4MHS StarTech.com 10 ft Ultra Thin USB VGA 2-in-1 KVM Cable In Stock £9.89
4MHS StarTech.com 6 ft 3-in-1 Ultra Thin PS/2 KVM Cable In Stock £6.42
4MHS StarTech.com 8 Port 1U Rackmount USB PS/2 KVM Switch with OSD In Stock £268.81
4MHS StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.58
4MHS StarTech.com DC Power Adapter - 9V, 2A In Stock £12.35
Type: KVM switch
Connectivity: KVM
Ports: 8
