StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables
Quicklinx: 7P3FWS00 Mfr#: SV831DUSBUK
Type: KVM switch
Connectivity: KVM
Ports: 8
12 In Stock
£317.20 ex VAT
£380.64 inc VAT
The SV831DUSBUK 8-port rack mount USB KVM switch kit offers a well-appointed KVM switch that includes all of the cables and accessories required to connect to 8 servers or PCs right out of the box, making setup convenient and simple.
The USB KVM delivers a dependable computer management tool that allows you to control up to 8 USB-connected computers from a single keyboard, mouse and display, providing maximum control through hotkey command-based switching or front panel push-buttons, with the added configurability and convenience of an On-Screen Display.
A suitable addition to server room operations, the 8-port switch can be rackmounted into 1U of cabinet space and can be cascaded with multiple KVM switches to enable control of up to 64 computers from this single switch.
  • Versatile connectivity
    The switch supports both USB keyboard and mouse connections, ensuring compatibility with a range of peripherals.
  • Space-saving design
    With a height of 1U, this rack-mountable KVM switch optimizes space in server racks while allowing for easy access to all ports.
  • Reliable performance
    Designed for an operational temperature range of 5°C to 40°C, this KVM switch maintains functionality in various environments.
  • Enhanced user experience
    Featuring indicators for port status and power, users can easily monitor the operational state of the KVM switch.
  • Scalable solution
    This KVM switch is cascadable, allowing for multiple units to be daisy-chained, which is suitable for expanding setups.
StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables - Rack mount KVM - VGA KVM Switch - 8 Port KVM Switch (SV831DUSBUK) - KVM switch - 8 ports - rack-mountable
KVM switch - 8 ports - cascadable
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Users Qty
1 local user
43.8 cm x 18 cm x 4.5 cm
2.9 kg
3-year warranty
P/N: 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12U, 4POSTRACK25U, 4POSTRACK42, RACKCOND17HD, RK1233BKM, RK12OD2, RK1833BKM, RK2433BKM, RK2537BKM, RK3236BKF, RK4236BKB, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M2NEUA, SVA12M5NA
Enclosure Type
Rack-mountable 1U
Subtype
KVM
Ports
8 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
Status Indicators
Port status, power
8 x KVM HD-15 , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
8 x keyboard / mouse / video cable
Rack Mounting Kit
Included
43.8 cm
18 cm
4.5 cm
2.9 kg
Limited warranty - 3 years
5 °C
P/N: 2636CABINET, 2POSTRACK12, 2POSTRACK16, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RACKCOND17HD, RK1233BKM, RK1236BKF, RK12OD, RK12OD2, RK1833BKM, RK2236BKF, RK2433BKM, RK2536BKF, RK2537BKM, RK3236BKF, RK4236BK, RK4236BKB, RK4242BK, RK4242BK24, RK4242BK30, RK8OD, RK960CP, RKCONS1701, RKCONS17HD, RKQMCAB12, RKQMCAB12V2, RKWOODCAB12, SVA12M2NEUA, SVA12M5NA, SVECONUS10, SVECONUS15, SVECONUS6, SVUSBVGA10, SVUSBVGA6
7P3F StarTech.com 4 Port Professional VGA USB KVM Switch with Hub In Stock £83.88
7P3F StarTech.com 1U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £36.10
7P3F StarTech.com 2U 19in Steel Vertical Wall Mount Equipment Rack Bracket In Stock £34.98
7P3F StarTech.com Long Range USB VGA KVM Console Extender over Cat5 UTP - 1000 ft In Stock £298.71
7P3F StarTech.com 16 Port 1U Rackmount USB KVM Switch with OSD In Stock £464.07
7P3F StarTech.com 16 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £527.07
7P3F StarTech.com 8 Port 1U Rackmount USB KVM Switch with OSD In Stock £280.59
7P3F StarTech.com 8 Port 1U Rackmount USB KVM Switch Kit with OSD and Cables In Stock £317.20
7P3F StarTech.com 8 Port 1U Rackmount DVI USB KVM Switch In Stock £618.82
7P3F StarTech.com 6 ft Ultra-Thin USB VGA 2-in-1 KVM Cable In Stock £7.40
7P3F StarTech.com DC Power Adapter - 12V, 2A In Stock £11.76
7P3F StarTech.com DC Power Adapter - 12V, 5A In Stock £42.05
7P3F StarTech.com 8-Port DisplayPort KVM Switch In Stock £408.00
7P3F StarTech.com 8-Port HDMI KVM Switch In Stock £502.49
Type: KVM switch
Connectivity: KVM
Ports: 8
