StarTech.com 8" Mini HDMI to DVI adapter
Quicklinx: BBD9WS00 Mfr#: HDCDVIMF8IN
£8.80 ex VAT
£10.56 inc VAT
Need to connect your Mini HDMI equipped laptop or tablet to a DVI-D digital display? This 8in Mini HDMI to DVI adapter provides the perfect solution.
  • High-resolution 1920x1200 video support
    Connect your Mini HDMI capable laptop or tablet to a DVI digital monitor, TV or projector, and share your presentations, pictures and videos. Simply plug in any one of our male-to-male DVI-D cables, such as our 3ft DVI-D single-link cable (DVIMM3) into the adapter and connect the adapter to your device. Perfect for use in a boardroom, your home office or when travelling for work, you can be ready to connect wherever you are. Need a way to incorporate audio into your presentation? You can use our 1m 3.5mm audio cable (MU3MMS).
  • 8-inch cable reduces port damage
    Reduce stress and prevent damage on the device port. The 8-inch cable design reduces the strain on the port as well as the connectors, plus it doesn't block other open ports, leaving them open for connecting other devices.
  • Compact and lightweight design
    The adapter fits nicely inside your laptop bag, purse, backpack or other carrying case, making it the perfect mobile accessory to keep in your carry-on baggage. Arrive prepared when presenting to a potential client, teaching offsite, or travelling to a customer location. The HDCDVIMF8IN Mini HDMI to DVI adapter is backed by StarTech.com's lifetime warranty.
StarTech.com 8 in Mini HDMI to DVI Cable Adapter, DVI-D to HDMI (1920x1200p), 19 Pin HDMI Mini (C) Male to DVI-D Female, Digital Monitor Adapter Cable M/F, 3.9 Gbps Bandwidth, Black - Mini HDMI to DVI Adapter - adapter - HDMI / DVI - 20.32 cm
Cable
Adapter - HDMI / DVI
Double shielded
American Wire Gauge (AWG)
30/32
Length
20.32 cm
Connector
DVI-D - female
Connector (Second End)
19 pin mini HDMI Type C - male
Cable Type
Adapter
Interface Supported
HDMI / DVI
Double shielded
30/32
Jacket Material
PVC
Shielding Material
Length
20.32 cm
Plated Connector
Gold
Connector
24+1 pin digital DVI - female
RoHS
Limited warranty - lifetime
