Connect your USB On-the-Go capable tablet or phone to an external drive or other USB 2.0 device. Now, you can download confidential information from your smartphone or tablet to an external drive, without having to use a Wi-Fi or mobile data connection. This 8 in. USB OTG cable gives you the perfect solution for backing up your important research and other data collected while you're on the road.
The cable turns the Micro-USB port on your mobile device into a USB OTG host port, so that you can connect a Micro-USB drive or other Micro-USB device, such as a game controller, directly to your phone or tablet.
The OTG cable features a compact design that's perfect for carrying as a tablet accessory.
Please Note: This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device supports USB OTG functionality.
- StarTech.com 8in Micro USB to Micro USB Cable - Male to Male - Micro USB OTG Cable for Your Mobile Device (UUUSBOTG8IN) - USB cable - Micro-USB Type B to Micro-USB Type B - 20.32 cm
- USB cable
- Technology
- Double shielded
- Length
- 20.32 cm
- Connector
- 5 pin Micro-USB Type B - male
- Connector (Second End)
- USB On-The-Go
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 20.32 cm
- Black
- 7 g
- Connector
- USB On-The-Go, RoHS
StarTech.com 5in Micro USB to USB OTG Host Adapter M/F | In Stock | £5.59 |
StarTech.com 8" Micro USB OTG Cable | In Stock | £5.76 |
