Connect your USB On-the-Go capable tablet or phone to an external drive or other Mini-USB device. Now, you can download confidential information from your smartphone or tablet to an external drive, without having to use a Wi-Fi or mobile data connection. This 8 in. USB OTG cable gives you the perfect solution for backing up your important research and other data collected while you're on the road.
The cable turns the Micro-USB port on your mobile device into a USB OTG host port, so that you can connect a Mini-USB drive or other Mini-USB device, such as a game controller, directly to your phone or tablet.
The OTG cable features a compact design that's perfect for carrying as a tablet accessory.
Please Note: This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device supports USB OTG functionality.
- StarTech.com 8in USB OTG Cable - Micro USB to Mini USB - M/M - USB OTG Mobile Device Adapter Cable - 8 inch (UMUSBOTG8IN) - USB cable - mini-USB Type B to Micro-USB Type B - 20.32 cm
- USB cable
- Technology
- Double shielded
- Length
- 20.32 cm
- Connector
- Mini-USB Type B - male
- Connector (Second End)
- 5 pin Micro-USB Type B - male
- USB On-The-Go
- Black
- Limited lifetime warranty
- USB cable
- Technology
- Double shielded
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 28
- Plated Connector
- Nickel
- Length
- 20.32 cm
- Black
- 7 g
- Connector
- USB On-The-Go, RoHS
StarTech.com 5in Micro USB to USB OTG Host Adapter M/F | In Stock | £5.82 |
StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F | In Stock | £5.10 |
StarTech.com 8" Micro USB OTG Cable | In Stock | £5.67 |
