StarTech.com 8" Micro to Mini USB OTG Cable
Quicklinx: BVV4WS00 Mfr#: UMUSBOTG8IN
Length: 20.32cm
More than 50 in stock
£4.28 ex VAT
£5.13 inc VAT
Connect your USB On-the-Go capable tablet or phone to an external drive or other Mini-USB device. Now, you can download confidential information from your smartphone or tablet to an external drive, without having to use a Wi-Fi or mobile data connection. This 8 in. USB OTG cable gives you the perfect solution for backing up your important research and other data collected while you're on the road.
The cable turns the Micro-USB port on your mobile device into a USB OTG host port, so that you can connect a Mini-USB drive or other Mini-USB device, such as a game controller, directly to your phone or tablet.
The OTG cable features a compact design that's perfect for carrying as a tablet accessory.
Please Note: This adapter will only work with devices that support USB OTG. Please consult your documentation and/or your service provider to ensure that your device supports USB OTG functionality.
StarTech.com 8in USB OTG Cable - Micro USB to Mini USB - M/M - USB OTG Mobile Device Adapter Cable - 8 inch (UMUSBOTG8IN) - USB cable - mini-USB Type B to Micro-USB Type B - 20.32 cm
USB cable
Double shielded
Length
20.32 cm
Connector
Mini-USB Type B - male
Connector (Second End)
5 pin Micro-USB Type B - male
USB On-The-Go
USB cable
Double shielded
Jacket Material
PVC
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
20.32 cm
7 g
Connector
USB On-The-Go, RoHS
BVV4 StarTech.com 5in Micro USB to USB OTG Host Adapter M/F In Stock £5.01
BVV4 StarTech.com 5in Right Angle Micro USB to USB OTG Host Adapter M/F In Stock £5.01
BVV4 StarTech.com 8" Micro to Mini USB OTG Cable In Stock £4.28
BVV4 StarTech.com 8" Micro USB OTG Cable In Stock £4.28
Length: 20.32cm
Price Range Ex VAT: 0 - 50
