MANAGED USB HUB: USB Hub Administrator software works with the USB hub to enable/disable ports or all ports and reboot the Hub; Windows, macOS, Linux; Supports CLI commands for custom application creation.
ROBUST and RELIABLE: With metal housing, 15kV/8kV level 4 ESD air/contact protection, this robust USB 3.2 Gen 1 5Gbps hub reliably connects 7 USB devices in harsh industrial environments.
POWER AND CHARGING: USB hub supports 7 to 48 volts DC; powered via terminal block connector with power adapter (part number: ITB20D3250); 6x USB-A ports capable of charging BC 1.2 (2.4A).
VERSATILE MOUNTING OPTIONS: This mountable USB hub installs securely on/under a desk, wall or DIN rail using the integrated mounting ears and DIN brackets included; 1.8 m USB 3.2 Gen 1 cable included.
CONNECTIVITY TOOLS: Includes Connectivity Tools application, enabling administrators to identify potentially malicious devices; TAA-compliant; Ideal for remote operations and device security.
Robust design
Crafted with metal industrial housing, this 7-Port Managed USB Hub is built to withstand harsh environments, making it ideal for heavy-duty applications. Its durability is further enhanced with ESD & Surge Protection, ensuring your devices remain safe from electrical damage. -
Versatile connectivity
Featuring 7x USB-A ports with support for USB 3.0/3.1/3.2 Gen 1 5 Gbps, this hub offers a wide range of connectivity options. It includes a USB-A to USB-B cable, facilitating easy connection to a variety of devices. -
Advanced management
Equipped with command-line interface (CLI) management, this hub allows for sophisticated control and monitoring of connected devices. It's designed to meet the needs of complex setups, providing both flexibility and reliability. -
Flexible installation
With options for Wall, Desk, and Din-Rail mounting, this USB hub offers versatile installation solutions to fit any workspace. Its form factor is designed for convenience, ensuring it can be placed exactly where it's needed. -
High reliability
Boasting an MTBF of 131,406 hours and compliance with multiple standards including RoHS, UASP, and WEEE, this hub is not only reliable but also meets strict environmental and safety standards.
- StarTech.com 7-Port Managed USB Hub with 7x USB-A, Heavy Duty with Metal Industrial Housing, ESD & Surge Protection, Wall/Desk/Din-Rail Mountable, USB 3.0/3.1/3.2 Gen 1 5Gbps - hub - 7 ports - TAA Compliant
- Hub - 7 ports
- Subtype
- USB
- Ports
- 6 x USB 3.2 Gen 2 + 1 x USB 3.2 Gen 1
- Surge protection, metal housing, 8KV ESD Protector (contact discharge), 15KV ESD Protector (air-gap discharge), managed, fast charging support, CLI management, lockable ports
- USB 1.1, USB 2.0, USB 3.0, USB 3.1, USB 3.2 Gen 2, USB 3.2 Gen 1, Battery Charging 1.2
- 11.4 cm x 6.7 cm x 2.6 cm
- 200 g
- Black
- TAA Compliant
- 2-year warranty
- Hub - 7 ports
- Enclosure Type
- Desktop, DIN rail mountable, wall-mountable
- Subtype
- USB
- Ports
- Status Indicators
- Port status, power
- 6 x USB 3.2 Gen 2 Type A Battery Charging 1.2 , 1 x USB 3.2 Gen 1 Type A , 1 x USB 3.2 Gen 1 Type B host , 1 x terminal block
- Black
- Included Accessories
- DIN-rail mounting kit, terminal block connector
- Cables Included
- 1 x USB-A to USB-B cable - 1.8 m
- MTBF
- 131,406 hours
- RoHS, WEEE, UASP (USB Attached SCSI Protocol)
- TAA Compliant
- 11.4 cm
- 6.7 cm
- 2.6 cm
- 200 g
- Shipping Width
- 21.3 cm
- Shipping Depth
- 14.9 cm
- Shipping Height
- 5.1 cm
- Shipping Weight
- 500 g
- Limited warranty - 2 years
- 0 °C
- 60 °C
- 5 - 95% RH
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 75 °C
