Make Power-over-Ethernet-capable Gigabit network connections. This 7-meter Cat6 cable meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections. Plus, the cable features a durable yellow PVC jacket that enables you to color code your network cable runs as needed.
For easier cable runs, the snagless connectors protect the cable's RJ45 clips during installation, making them less likely to snag or break. This ensures a sturdy connection by preventing the cable from becoming loose from the port.
The cable features molded boots that offer connector strain relief, by stopping the RJ45 connector termination points from bending at sharp angles, and reducing the risk of damage to the cable, which could decrease network performance.
- StarTech.com 7m CAT6 Ethernet Cable - Yellow Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATC7MYL) - patch cable - 7 m - yellow
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568B
- Snagless, minimised Near-End Crosstalk (NEXT)
- Length
- 7 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- Yellow
- Limited lifetime warranty
- Network Cable Type
- Technology
- Wiring Scheme
- T568B
- Jacket Material
- PVC
- American Wire Gauge (AWG)
- 24
- Pairs per Cable
- 4 pairs
- Plated Connector
- Gold
- Length
- 7 m
- 308 g
- Yellow
- Connector
- RJ-45 - male
- RJ-45 - male
- RoHS, ETL, TIA/EIA-568-B - up to 500 MHz
StarTech.com 7m Black Gigabit Snagless RJ45 UTP Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m Green Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m Gray Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m Red Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m Yellow Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m Orange Cat6 Patch Cable | In Stock | £7.42 |
StarTech.com 7m White Cat6 Patch Cable | In Stock | £7.42 |
